数据: SN74CB3T3245 8-Bit FET Bus Switch 2.5-V and 3.3-V Low-Voltage With 5-V-Tolerant Level Shifter 数据表
SN74CB3T3245器件是一款高速TTL兼容的8位FET总线开关,具有低导通电阻(r on ),允许最小的传播延迟。该器件通过提供跟踪V CC 的电压转换,完全支持所有数据I /O端口的混合模式信号操作。
所有商标均为其各自所有者的财产。
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| Input/Output ON-state Capacitance (Typ) (pF) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| SN74CB3T3245 |
| 1:1 SPST |
| 8 |
| Single |
| N/A |
| N/A |
| 2.3 |
| 3.6 |
| 5 |
| 100 |
| Catalog |
| -40 to 85 |
| 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) 20SSOP: 52 mm2: 6 x 8.65(SSOP) 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) 20TVSOP: 32 mm2: 6.4 x 5(TVSOP) |
| SOIC SSOP TSSOP TVSOP |
| 3.6 |
| 8.5 |
| 128 |
| 20 |
| Powered off protection Signal path Translation |
| 10 |
| 5 |
| 5 |
| 1 |
| 2 |
| 0.8 |
| 1.7 |
