SN74CBTLV16212 低电压 24 位 FET 总线交换开关
数据:
SN74CBTLV16212提供24位高速总线切换或交换。开关的低导通状态电阻允许以最小的传播延迟进行连接。
该器件作为24位总线开关或12位总线交换器运行,提供数据交换。通过数据选择(S0,S1,S2)端子连接四个信号端口。
该器件完全适用于使用I off 的部分断电应用。 I off 功能可确保损坏的电流在断电时不会回流通过器件。电源关闭时设备具有隔离功能。
SN74CBTLV16212由先断后合功能指定,在B端口之间切换时没有直通电流。
特性
  • Member of the Texas Instruments Widebus™ Family
  • 4- Switch Connection Between Two Ports
  • Rail-to-Rail Switching on Data I/O Ports
  • Ioff Supports Partial-Power-Down Mode Operation
  • Break-Before-Make Feature
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Protection Exceeds JESD 22
    • 2000-V Human-Body Model (A114-A)
    • 200-V Machine Model (A115-A)
Widebus is a trademark of Texas Instruments.
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Max) (uA)
Features
OFF-state leakage current (Max) (µA)
ON-state leakage current (Max) (µA)
Input/Output OFF-state Capacitance (Typ) (pF)
ESD HBM (kV)
VIL (Max) (V)
VIH (Min) (V)
SN74CBTLV16212
crosspoint/exchange
24
Single
N/A
N/A
2.3
3.6
3
200
Catalog
-40 to 85
56SSOP: 191 mm2: 10.35 x 18.42(SSOP)
56TSSOP: 113 mm2: 8.1 x 14(TSSOP)
56TVSOP: 72 mm2: 6.4 x 11.3(TVSOP)
SSOP
TSSOP
TVSOP
3.6
40
128
10
Powered off protection
1
1
8
2
0.8
2
技术文档
数据手册(1)
元器件购买 SN74CBTLV16212 相关库存
