'CBT16244器件在标准'16244器件引脚排列中提供16位高速TTL兼容总线切换。开关的低导通电阻允许以最小的传播延迟进行连接。
这些器件由4个4位低阻抗开关组成,具有独立的输出使能(OE)输入。当OE \为低电平时,开关打开,数据可以从端口A流到端口B,反之亦然。当OE \为高电平时,开关打开,两个端口之间存在高阻状态。
在两个端口之间切换连接Widebus是德州仪器公司的商标。
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Max) (uA) |
| OFF-state leakage current (Max) (µA) |
| ON-state leakage current (Max) (µA) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| SN74CBT16244 |
| 1:1 SPST |
| 16 |
| Single |
| N/A |
| N/A |
| 4 |
| 5.5 |
| 5 |
| 200 |
| Catalog |
| -40 to 85 |
| 48SSOP: 164 mm2: 10.35 x 15.88(SSOP) 48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP) 48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP) |
| SSOP TSSOP TVSOP |
| 5.5 |
| 20 |
| 128 |
| 3 |
| 1 |
| 1 |
| 4.5 |
| 0.8 |
| 2 |
