TLC2551 12 位 400kSPS ADC,具有串行输出、TMS320 兼容(最高 10MHz)和单通道
数据:
产品信息
描述The TLC2551, TLC2552, and TLC2555 are a family of high performance, 12-bit, low-power, miniature, CMOS analog-to-digital converters (ADC). The TLC255x family uses a 5-V supply. Devices are available with single, dual, or single pseudo-differential inputs. Each device has a chip select (CS)\, serial clock (SCLK), and serial data output (SDO) that provides a direct 3-wire interface to the serial port of most popular host microprocessors (SPI interface). When interfaced with a TMS320™ DSP, a frame sync signal (FS) can be used to indicate the start of a serial data frame on CS\ for all devices or on FS for the TLC2551. The TLC2551, TLC2552, and TLC2555 are designed to operate with very low power consumption. The power saving feature is further enhanced with an autopower down mode. This product family features a high-speed serial link to modern host processors with SCLK up to 20 MHz. The maximum SCLK frequency is dependent upon the mode of operation (see Table 1). The TLC255x family uses the SCLK as the conversion clock, which provides synchronous operation and a minimum conversion time of 1.5 µs using a 20 MHz SCLK.特性Maximum Throughput . . . 175/360 KSPS INL/DNL: ±1 LSB Max, SINAD: 72 dB, SFDR: 85 dB, fi = 20 kHz SPI/DSP-Compatible Serial Interface Single 5-V Supply Rail-to-Rail Analog Input With 500 kHz BW Three Options Available: TLC2551: Single Channel Input TLC2552: Dual Channels With Autosweep TLC2555: Single Channel With Pseudo-Differential Input Low Power With Autopower Down Operating Current: 3.5 mAAutopower Down: 8 µA Small 8-Pin MSOP and SOIC PackagesTMS320 is a trademark of Texas Instruments.
技术文档
数据手册(1)
元器件购买 TLC2551 相关库存
相关阅读
