SN65LBC173和SN75LBC173是具有三态输出的单片四路差分线路接收器。两者均旨在满足ANSI标准EIA /TIA-422-B,EIA /TIA-423-B,RS-485和ITU建议V.10和V.11的要求。这些器件针对平衡多点总线传输进行了优化,数据速率高达每秒超过1000万比特。四个接收器共享两个ORed使能输入,一个在高电平时有效,另一个在低电平时有效。
每个接收器都具有高输入阻抗,输入滞后以提高抗噪性,输入灵敏度为±200 mV,共模输入电压范围为12 V至-7 V.故障安全设计可确保如果输入是开路的,输出总是很高。这两款器件均采用德州仪器(TI)专有的LinBiCMOS TM 技术设计,可提供低功耗,高开关速度和稳健性。
与SN75LBC172或SN75LBC174四线驱动器配合使用时,这些器件可提供最佳性能。 SN65LBC173和SN75LBC173采用16引脚DIP(N)和SOIC(D)封装。
SN65LBC173的工业温度范围为-40°C至85°C。 SN75LBC173的特点是在0°C至70°C的商用温度范围内工作。
| Supply Voltage(s) (Nom) (V) |
| No. of TX |
| No. of RX |
| Duplex |
| Signaling Rate (Max) (Mbps) |
| IEC 61000-4-2 Contact (+/- kV) |
| HBM ESD (kV) |
| Fault Protection (V) |
| Number of Nodes |
| Common Mode Range |
| ICC (Max) (mA) |
| Isolated |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Approx. Price (US$) |
| SN75LBC173 | SN55LBC172 | SN55LBC173 | SN65LBC172 | SN65LBC173 | SN75LBC172 |
| 5 | 5 | 5 | 5 | 5 | 5 |
| 0 | 4 | 0 | 4 | 0 | 4 |
| 4 | 0 | 4 | 0 | 4 | 0 |
| N/A | N/A | N/A | N/A | N/A | N/A |
| 10 | 10 | 10 | 10 | 10 | 10 |
| N/A | N/A | N/A | N/A | ||
| 2 | 2 | 2 | 2 | 2 | 2 |
| -10 to 15 | -10 to 15 | -10 to 15 | -10 to 15 | -10 to 15 | -10 to 15 |
| 32 | 32 | 32 | 32 | 32 | 32 |
| -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 | -7 to 12 |
| 20 | 7 | 11 | 7 | 20 | 7 |
| No | No | No | No | No | No |
| Catalog | Military | Military | Catalog | Catalog | Catalog |
| 0 to 70 | -55 to 125 | -55 to 125 | -40 to 85 | -40 to 85 | 0 to 70 |
| PDIP SOIC | CDIP CFP LCCC | CDIP CFP LCCC | PDIP SOIC | PDIP SOIC | PDIP SOIC |
| 1.21 | 1ku | 2.43 | 1ku | 1.33 | 1ku | 1.89 | 1ku | ||
| 无样片 | 无样片 |
