SN74CBTLV3383 低电压 10 位 FET 总线交换开关
数据:
The SN74CBTLV3383 provides ten bits of high-speed bus switching or exchanging. The low on-state resistance of the switch allows connections to be made with minimal propagation delay.
The device operates as a 10-bit bus switch or as a 5-bit bus exchanger, which provides swapping of the A and B pairs of signals. The bus-exchange function is selected when BX is high, and BE\ is low.
This device is fully specified for partial-power-down applications using Ioff. The Ioff feature ensures that damaging current will not backflow through the device when it is powered down. The device has isolation during power off.
特性
  • 5- 在两个端口之间切换连接
  • 数据I /O端口上的轨到轨切换
  • I off 支持部分断电模式操作< /li>
  • 闩锁性能每JESD超过250 mA 17
  • ESD保护超过JESD 22
    • 2000-V人体模型(A114-A)
    • 200-V机型(A115-A)
参数 与其它产品相比 模拟开关/多路复用器
Configuration
Number of Channels (#)
Power Supply Type
Vss (Min) (V)
Vss (Max) (V)
Vdd (Min) (V)
Vdd (Max) (V)
Ron (Typ) (Ohms)
Bandwidth (MHz)
Rating
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Supply Range (Max)
Ron (Max) (Ohms)
Input/Output Continuous Current (Max) (mA)
Supply Current (Max) (uA)
Features
OFF-state leakage current (Max) (µA)
ON-state leakage current (Max) (µA)
Input/Output ON-state Capacitance (Typ) (pF)
Input/Output OFF-state Capacitance (Typ) (pF)
ESD Charged Device Model (kV)
ESD HBM (kV)
VIL (Max) (V)
VIH (Min) (V)
SN74CBTLV3383 SN74CBT3383C
crosspoint/exchange     crosspoint/exchange
10     10
Single     Single
N/A     N/A
N/A     N/A
2.3     4
3.6     5.5
5     3
200     200
Catalog     Catalog
-40 to 85     -40 to 85
24SOIC: 160 mm2: 10.3 x 15.5(SOIC)
24SSOP: 52 mm2: 6 x 8.65(SSOP)
24TSSOP: 50 mm2: 6.4 x 7.8(TSSOP)
24TVSOP: 32 mm2: 6.4 x 5(TVSOP)
SOIC
SSOP
TSSOP
TVSOP
SOIC
SSOP
TSSOP
3.6     5.5
40     12
128     128
10     3
Powered off protection     Powered off protection
-2V undershoot protection
1     10
1
  18.5
13.5     8
  1
2     2
0.8     0.8
2     2
技术文档
数据手册(1)
元器件购买 SN74CBTLV3383 相关库存
