德克萨斯大学:研究石墨烯电子纹身电生理传感,用于潜水员安全检测
传感器专家网 来源:传感器专家网 作者:传感器专家网 2025-07-13 17:39 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
危险且缺乏保护的水下作业是潜水员死亡的主要原因;生物传感器可提供早期预警和部分保护,从而在一定程度上减轻这一风险。然而,当前生物传感器的复杂性和高成本限制了其广泛应用,凸显了对有效、成本效益高且多功能生理监测解决方案的迫切需求。本文,德克萨斯大学Deji Akinwande、马萨诸塞大学Dmitry Kireev等在《ACS Applied Electronic Materials》期刊发表名为“Electrophysiological Sensing with Graphene Electronic Tattoos for Saline and Underwater Environments”的论文,研究开发了一种非侵入式防水石墨烯电生理传感器,可在盐水环境中检测多种生理信号,从而克服现有水下监测技术的局限性。通过采用原子级薄的石墨烯界面和简单的防水涂层方法,我们实现了在皮肤表面采集心电图(ECG)、肌电图(EMG)和皮肤电活动(EDA)信号。
此外,我们通过EDA信号准确评估了惊吓事件,这对于评估潜水员压力和预防事故至关重要。该防水石墨烯生物传感器展现出卓越的电学性能,包括在10 kHz频率下阻抗低至约2.4 kΩ·cm²、EMG信号信噪比超过21 dB,以及EDA信号响应速度高达0.125 μS/(s·cm²),所有测试均在盐水条件下进行。本研究为防水石墨烯电生理传感器在盐水环境中的巨大潜力提供了有力证据,为提升潜水员安全性和降低事故风险提供了解决方案。
2图文导读
图1. Water-resistant GET (Graphene Electronic Tattoo) structure and functional diagram. (a) Schematic representation of the integrated structure of SCC-GET. (b) Close-up optical photograph of a single GET, and a GET connected to gold tape adhered to the forearm. The skin surface has been treated with a waterproof coating. (c) Schematic representation of a SCC-GET sensor, which is capable of detecting electrocardiogram (ECG), electromyogram (EMG), and electrodermal activity (EDA) signals in saline environments.
图2. Comparative impedance spectra of GET under diverse coating conditions for water resistance performance. (a) Skin crack care (SCC) coated GET full spectrum impedance sweep for all test conditions. (b) The mean impedance of GET using different waterproofing methods (Tegaderm film-coated commercial electrodes, Tegaderm film-coated GET, Skin Crack Care (SCC) coated GET, and Waterproof spray-coated GET), under different test conditions (bare in air, coated in air, coated in DI water, and coated in PBS solution), measured at different frequencies (100 Hz, 1 kHz, and 10 kHz). The area of the commercial electrodes was normalized to match the surface area of the GET for comparative analysis.
图3. ECG signal recorded from SCC coated GET. (a) ECG signals measured in air from GET (light orange), under 30 cm of deionized (DI) water (light blue), under 30 cm of PBS solution (dark blue), and Ag/AgCl commercial electrodes (green) in air. (b) ECG signal measured by GET in air, capturing a complete cardiac cycle and marking the different phases within the cycle. (c) Violin plot of sinus rhythm R–R intervals (heart rate) calculated from ECG signals under different conditions. The width of the violin represents the data density, the center bar shows the interquartile range, and the dot within the bar marks the median. (d) Diagram of three-lead ECG signal measurement.
图4. EMG signal recorded from SCC coated GET. (a) EMG signals measured simultaneously in air from SCC-GET (dark orange) and Ag/AgCl commercial electrodes (green). EMG signals from SCC-GET measured under 30 cm of deionized (DI) water (light blue) and under 30 cm of PBS solution (dark blue). (b) Signal-to-noise ratio for different measurement conditions (n= 12, 10 grabs, and 2 holds). The bars represent the mean values, with error bars indicating the standard deviation (mean ± SD). (c) Optical photograph of simultaneous EMG signal measurements using graphene electrodes and commercial electrodes (cut into 0.25 cm2), located on the subject’s forearm.
图5. EDA signal recorded from SCC coated GET. (a) Schematic diagram of the working principle for EDA signal measurement. (b) EDA signals measured with SCC-GET in DI water, recorded while subjects watched three types of videos: meditative, serene, and terrifying. The green dashed line indicates where subjects stabilized their emotional fluctuations, while the green arrow highlights the specific moment. (c) EDA signals measured with SCC-GET in DI water, recorded while subjects watched a 10 min terrifying video. (d) Comparison of EDA signal peaks (using area-normalized conductance) while watching terrifying videos measured with SCC-GET under different conditions (DI water, PBS, air) and commercial electrodes (air only). Normalized by area (n= 9 for commercial metal button electrodes in air,n= 9 for bare GET in air,n= 7 for SCC-GET in air,n= 6 for SCC-GET in DI,n= 8 for SCC-GET in PBS). The box represents 25% and 75% with a mean; outliers are ±SD. (e) Comparison of EDA signals baselines (median of tonic component), using area-normalized conductance, measured with GET under different conditions and commercial electrodes in air.
3小结
研究推出了一种新型皮肤裂纹护理增强型防水石墨烯电子纹身(SCC-GET),展示了其在盐水环境中各种生物电子应用中的有效性。通过将原子级薄的石墨烯与柔性、透明且防水的层相结合,SCC-GET实现了亚微米级厚度,并能与人体皮肤无缝贴合,不受运动影响,使其成为迄今为止在盐水条件下报道的最薄的电生理传感器。SCC-GET的便捷组装特性使其可同时放置于多个身体部位以同步检测生命体征信号。总体而言,本研究证实了SCC-GET在多种生物电子应用中的优异性能与可靠性,为先进生理监测系统的发展奠定了基础,尤其在海洋等极端环境中具有广阔应用前景。
  • 石墨烯
  • 安全检测
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    一文读懂石墨检测:为何它是石墨产业的“质量守门人”?
    符合特定的应用要求。“石墨检测”是指对天然石墨、人造石墨、高纯石墨、膨胀石墨
    的头像 发表于 03-06 16:17 340次阅读
    一文读懂<b class='flag-5'>石墨</b><b class='flag-5'>检测</b>:为何它是<b class='flag-5'>石墨</b>产业的“质量守门人”?
    锁相放大器在观察石墨自发对称性破缺的量子输运测量的应用
    上海交通大学人工结构及量子调控教育部重点实验室证明了结晶多层石墨研究由库伦相互作用驱动的各种对称破缺的理想平台。石墨
    的头像 发表于 02-09 16:27 306次阅读
    锁相放大器在观察<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>自发对称性破缺的量子输运测量的应用
    高压功率放大器在三维石墨应变传感网络研究中的应用
    实验名称: 高分辨三维石墨应变传感网络及其自监测变形器件 研究方向: 针对复杂变形场下的高精度感知需求,研究基于三维
    的头像 发表于 01-26 10:55 446次阅读
    高压功率放大器在三维<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>应变<b class='flag-5'>传感</b>网络<b class='flag-5'>研究</b>中的应用
    用于氧化石墨的多模态表征与激光还原图案化的共聚焦显微技术
    氧化石墨(GO)是制备导电还原氧化石墨(rGO)的重要前驱体,在柔性电子、储能等领域应用广泛。激光还原因无掩模、局部精准的优势成为GO图
    的头像 发表于 12-16 18:03 591次阅读
    <b class='flag-5'>用于</b>氧化<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>的多模态表征与激光还原图案化的共聚焦显微技术
    香港理工大学、南方科技大学:新型压阻式石墨/CNC声学传感器,用于语音识别
    Recognition”的论文,研究开发了一种新型压阻式声学传感器,通过气溶胶喷射打印技术,采用聚氨酯(PU)薄膜封装石墨/纤维素纳米晶体(CNCs)进行增材制造。该
    的头像 发表于 11-27 18:28 586次阅读
    香港理工<b class='flag-5'>大学</b>、南方科技<b class='flag-5'>大学</b>:新型压阻式<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>/CNC声学<b class='flag-5'>传感</b>器,<b class='flag-5'>用于</b>语音识别
    深圳大学:研发新型传感器,实现阿摩尔级生物分子精准检测
    双层石墨(tBLG)的超晶格特性与等离激元共振效应,实现了无需核酸扩增的阿摩尔级生物分子检测研究团队将9.4°扭转双层石墨
    的头像 发表于 11-21 15:32 707次阅读
    深圳<b class='flag-5'>大学</b>:研发新型<b class='flag-5'>传感</b>器,实现阿摩尔级生物分子精准<b class='flag-5'>检测</b>
    深圳技术大学:超薄石墨应变传感器阵列,用于毫米级分辨率的高灵敏度多功能传感
    石墨柔性传感器阵列的应用受两大限制制约:现有制备方法难以实现高空间分辨率,且缺乏面向实际应用的系统级集成方案。为应对这些挑战,本文,深圳技术大学贾原 副教授、天津师范
    的头像 发表于 10-11 18:38 6061次阅读
    深圳技术<b class='flag-5'>大学</b>:超薄<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>应变<b class='flag-5'>传感</b>器阵列,<b class='flag-5'>用于</b>毫米级分辨率的高灵敏度多功能<b class='flag-5'>传感</b>
    高精度TLM测量技术:在金属-石墨接触电阻表征中的应用研究
    石墨作为最具代表性的二维材料,凭借其卓越的电学性能在高性能电子器件领域展现出巨大应用潜力。然而,金属-石墨接触电阻问题一直是制约其实际应
    的头像 发表于 09-29 13:46 989次阅读
    高精度TLM测量技术:在金属-<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>接触电阻表征中的应用<b class='flag-5'>研究</b>
    石墨超低方阻的实现 | 霍尔效应模型验证
    石墨因其高载流子迁移率(~200,000cm²/V·s)、低方阻和高透光性(~97.7%),在电子应用领域备受关注。然而,单层石墨的电学
    的头像 发表于 09-29 13:44 1090次阅读
    <b class='flag-5'>石墨</b><b class='flag-5'>烯</b>超低方阻的实现 | 霍尔效应模型验证
    东华大学研究基于石墨纤维的高性能压力传感器,具有双边致密结构,用于人体运动监测
    策略,通过调控石墨纤维(GF)的形态结构优化导电网络。最终成功制备出高导电性(3.19×10⁴ S m⁻¹)、抗拉强度达179.6 MPa、应变能力达6.5%的致密带状GF,并将其应用于柔性压力
    的头像 发表于 09-08 17:34 1773次阅读
    东华<b class='flag-5'>大学</b>:<b class='flag-5'>研究</b>基于<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>纤维的高性能压力<b class='flag-5'>传感</b>器,具有双边致密结构,<b class='flag-5'>用于</b>人体运动监测
    安徽大学:基于聚乙烯醇/丝素蛋白/石墨水凝胶的柔性传感器,用于先进的可穿戴电子产品等
      当前的柔性应变传感器受限于狭窄的应变检测范围、脆性特性及较差的环境适应性。本文,安徽大学郭小辉、Weiqiang Hong,郑州大学Peng Wang 等
    的头像 发表于 09-07 17:46 1649次阅读
    安徽<b class='flag-5'>大学</b>:基于聚乙烯醇/丝素蛋白/<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>水凝胶的柔性<b class='flag-5'>传感</b>器,<b class='flag-5'>用于</b>先进的可穿戴<b class='flag-5'>电子</b>产品等
    中科院宁波材料所:双结构石墨/PDMS复合传感器,用于可穿戴设备应用
    在实际应用中,柔性传感器需要在宽广的测量范围内展现出足够高的灵敏度;然而,这种需求总是伴随着权衡取舍。本文通过对激光诱导石墨(LIG)导电路径的几何创新,解决了上述挑战。本文, 中科院宁波材料所赵
    的头像 发表于 08-26 18:02 5977次阅读
    中科院宁波材料所:双结构<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>/PDMS复合<b class='flag-5'>传感</b>器,<b class='flag-5'>用于</b>可穿戴设备应用
    EastWave应用:光场与石墨和特异介质相互作用的研究
    本案例使用“自动计算透反率模式”研究石墨和特异介质的相互作用,分析透反率在有无石墨存在情况下的变化。光源处于近红外波段。  模型为周期结
    的头像 发表于 08-13 15:36 531次阅读
    EastWave应用:光场与<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>和特异介质相互作用的<b class='flag-5'>研究</b>
    泰科电子生理导管消融技术解读
    心脏疾病,尤其是心律失常,发病率正逐年攀升,面对这一挑战,生理(EP)导管消融技术凭借其精准和安全的治疗优势,越来越被临床医生选为首选治疗方案。
    的头像 发表于 07-14 17:30 1324次阅读
    浙江大学研究石墨基嗅觉传感阵列实现细菌和病毒性呼吸道感染的快速区分
    研究团队通过气敏受体调控策略构建了超灵敏高识别度的石墨的嗅觉传感器。研究表明还原氧化石墨
    的头像 发表于 05-28 17:34 2788次阅读
    浙江<b class='flag-5'>大学</b>:<b class='flag-5'>研究</b><b class='flag-5'>石墨</b><b class='flag-5'>烯</b>基嗅觉<b class='flag-5'>传感</b>阵列实现细菌和病毒性呼吸道感染的快速区分
