石墨烯柔性传感器阵列的应用受两大限制制约:现有制备方法难以实现高空间分辨率,且缺乏面向实际应用的系统级集成方案。为应对这些挑战,本文,深圳技术大学贾原 副教授、天津师范大学王程 副教授、哈尔滨工业大学Hao Sun等研究人员在《ADVANCED SENSOR RESEARCH》期刊发表名为“Ultrathin Graphene Strain Sensor Arrays for High-Sensitivity Multifunctional Sensing with Millimeter-Scale Resolution”的论文,研究提出基于超薄石墨烯应变传感器阵列的全集成平台。该阵列采用化学气相沉积法生长的石墨烯与自上而下微加工技术,制备于5微米厚聚酰亚胺基板上。通过4×4布局与1mm单元间距设计,实现约64units cm−2的器件密度,从而达到毫米级空间分辨率。
该平台整合了完整的开发流程,涵盖传感器阵列制造、柔性电路设计、信号控制及数据采集。耐久性测试显示其在5000次弯曲循环中性能稳定。应变灵敏度测量表明,在0.8%应变下最大应变系数达144,动态测试则呈现0.2秒的快速响应时间与0.16秒的松弛时间。该平台可可靠解析局部压力分布、监测动脉脉搏波形并识别表面曲率,充分展现其多功能传感能力。这些成果证实了该平台在可穿戴健康监测、柔性机器人及新一代柔性电子设备领域的实际应用可行性。
2图文导读
图1、Structure, sensing mechanism, and fabrication process of the sensor. a) The photograph of the strain sensor array; b) schematic illustration of the work mechanism; c) schematic illustration of sensor's fabrication process; d) 2D and 3D AFM micrograph of the PI film; e) microscopic image of the strain sensor array; e) Raman spectrum of the purchased CVD graphene; f) SEM micrograph of the purchased graphene.
图2、Data acquisition system. a) Photograph of custom DAQ and flexible printed circuit (FPC); b) schematic diagram of the Custom data acquisition (DAQ)board and the electrode lead-out (ELO) board; c) block diagram of the working principle of the main program in PC and sub program in the microcontroller.
图3、a) Durability of the strain sensor in bending–release cycles, photograph inserted on the right showing the bending and flattening stage of the sensor; b) comparison of strain response between the strain sensor and a commercial metal strain gauge under identical test conditions; c) consistency inspection of 16 strain sensors; d) responses of the sensor to diverse radii curvature; e) response/recovery times of the sensor.
图4、a) Photograph of testing and the radius measurement of the cylindrical object; b) schematic diagram of the row and column indexing of the sensor array; c) 3D bar charts of the sensor array responses to strain applied at six different regions, accompanied by schematic illustrations of the corresponding pressing points.
图5、a) The acquisition process of pulse waveforms; b) pulse waveforms detection results; c) comparison of pulse signals at seven random feature points before and after 24 h; d) pulse waveforms from four volunteers.
图6、3D bar charts and contour plots of sensor array responses to objects with different surface curvatures.
3小结
一种基于石墨烯的完全集成应变传感器阵列平台已在超薄聚酰亚胺基板上成功开发,实现了高空间分辨率、机械顺应性和应变灵敏度的理想组合。通过自上而下的微加工技术,将16个传感单元制备成0.5×0.5 cm²阵列,密度达≈64个器件/cm²。该阵列在5000次弯曲循环中表现稳定,并在0.8%应变下实现144的最大应变系数。局部载荷测试证实其具备毫米级分辨率且串扰极低。应用级验证包括脉搏波形监测与曲率微分测试,证实了该平台的多功能传感能力。这些成果凸显了超薄基板在提升机械适应性与传感精度的有效性。该平台为可穿戴电子设备、机器人皮肤及人机界面中的柔性传感提供了可扩展且可靠的解决方案。未来研究将聚焦阵列规模化与片上信号处理,以实现高吞吐量的智能触觉传感。
文献:
https://doi.org/10.1002/adsr.202500089
柔性电路
54浏览量
13258 -
石墨烯
54文章
1612浏览量
84594 -
应变传感器
69浏览量
5031 -
柔性传感器
1文章
114浏览量
4761
ADC分辨率与精度的区别是什么
深圳大学:研发新型传感器,实现阿摩尔级生物分子精准检测
Vishay高灵敏度接近与环境光传感器—VCNL4200
中国医科大学:在室温下获得超高灵敏度的NO2传感,用于哮喘诊断
CX3上的AR0245传感器的探头控制分辨率错误怎么解决?
研究用于人体足底压力和步态分析的高灵敏度压力传感器
Vishay Opto VEML6031X00汽车级环境光传感器
一种具有高度异质性、高灵敏度-单分子分辨率传感器的开发利用
基于石墨烯应变传感复合材料,用于先进可穿戴传感器
深圳技术大学:超薄石墨烯应变传感器阵列,用于毫米级分辨率的高灵敏度多功能传感
