安徽大学:基于聚乙烯醇/丝素蛋白/石墨烯水凝胶的柔性传感器,用于先进的可穿戴电子产品等
传感器专家网 来源:材料分析与应用 作者:材料分析与应用 2025-09-07 17:46 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
当前的柔性应变传感器受限于狭窄的应变检测范围、脆性特性及较差的环境适应性。本文,安徽大学郭小辉、Weiqiang Hong,郑州大学Peng Wang 等研究人员在《Sensors and Actuators B: Chemical》期刊发表名为“Polyvinyl Alcohol/Silk Fibroin/Graphene Hydrogel-Based Flexible Sensor with Self-Healing, Ultra-Stretchable, and Eco-Friendly Properties for Advanced Wearable Electronics and Human-Machine Interaction Applications”的论文,研究提出了一种基于环保型纳米复合材料的离子导电水凝胶。该传感材料具备自愈合与可降解特性,且能在宽广范围内对拉伸应变作出敏感响应。该水凝胶通过将聚乙烯醇(PVA)、硼砂、丝素蛋白(SF)、单宁酸(TA)、氯化钠和石墨烯(GR)按特定比例混合合成。硼砂与PVA形成的硼酸酯键可聚合PVA内部的高分子链,赋予水凝胶自愈合能力。
丝素蛋白的引入作为增强剂,稳定了硼砂与PVA之间的非牛顿流体行为。丝素蛋白与单宁酸的结合赋予了水凝胶自愈合能力,并提升了其力学性能和粘弹性。作为导电材料,石墨烯可显著提高水凝胶的导电性。基于水凝胶的传感器具有良好的拉伸性(>6000%)、超快速响应/恢复时间(12.5 ms)、宽广的应变检测范围(>400%)以及在受到外部力量损坏后良好的自愈合能力。该传感器的应用示例包括皮肤友好型贴片和人体运动监测。对于超大应变监测,该设备可成功应用于降落伞下降过程的监测。
图文导读
图1.(a) Preparation process of hydrogel. (b) Multiple complexations among components within the hydrogel. (c) Formation mechanism of dynamic reversible boronic ester bonds between PVA chains and borax.
图2.Characterization of hydrogels. (a-d) Internal 3D network structure and micro-morphology of hydrogel. (e) Small networks extend from hydrogel networks. (f,g) EDS images of hydrogel. (h) FTIR images of hydrogel and its components. (i) XRD images of hydrogel and its components.
图3.(a) Resistive response of hydrogel at different strains. (b)I-Vvariation of hydrogel within the strain range of 0-800%. (c) Response/recovery time of hydrogel at 2% strain. (d) Experimental results of hydrogel under cyclic tests at 5%, 20%, and 50%. (e) Signal output curves of hydrogels at different stretch/release rates (25mm/min, 50mm/min, 100mm/min, 200mm/min). (f) Relative resistance change of hydrogel under gradually applied strain ranging from 0-10%. (g) Tensile loading-unloading curve at 30% strain. (h) Continuous cycling test of hydrogel at 30% stretch for 2500 cycles.
图4.(a) Effect of presence or absence of SF on the response properties of hydrogels. (b) Effect of NaCl on the tensile properties of hydrogels in a cold environment. (c) Comparison of response properties of hydrogels before and after being pulled apart. (d) Tensile properties of the samples in this paper before and after placing them in a cold environment. (e) Comparison of tensile multiplicity and sensitivity of this study with other references. (f) Comparative demonstration of hydrogel skin-friendly properties. (g) Demonstration of hydrogel degradation properties.
图5.(a) Conceptual diagram of a small smart combination box. (b) Set the knob to the “off” position. (c) Input “00” to the knob. (d) Invalid interval between " OFF" and "00" (e) Input the correct combination. The safe opens. (f) Input the wrong password. Trigger the error reminder.
图6.(a) Conceptual diagram for signal acquisition during shooting motion. (b) The hydrogel was damaged during exercise and quickly repaired itself. (c) Volunteer makes a shooting motion. (d) Wrist signal response when a shot is successful. (e) Wrist signal response when the volunteer is in a designated shooting position. (f) Elbow signal response when a shot is successful. (g) Elbow signal response when the volunteer is in the spotting position. (h) Knee signal response when a shot is successful. (i) Knee signal response when the volunteer is in the spot-up shooting position. (j) Categorization of 40 shots according to the magnitude of the gap between the shooting motion and the hitting motion. (k) Shots with an accuracy gesture between shooting motion and hitting motion. (l) Hits when there is an inaccuracy gesture between shooting motion and hitting motion.Fig. 6j shows that 24 of the 40 sets of movements have a small difference from the movements at the time of the hit, and 16 of the 40 sets of movements have a large difference from the movements at the time of the hit.Fig. 6k demonstrates that the hitting situation in the movements with a small gap and hitting time. There are 8 hits in 24 shots, and the hitting rate is about 33%.Fig. 6l reveals the hitting situation in the movements with a large gap and hitting time. There are 0 hits in 16 shots, and the hitting rate is 0. It can be seen that the sensor has a certain effect on shooting training for beginner basketball players. In addition, the hydrogel has low cost and is harmless to the environment, and can be rapidly degraded after being discarded without causing harm to the environment.
图7.(a) Three main stages of parachute descent, (I) Free fall stage (II) Parachute opening fall stage (III) landing stage. (b) Schematic diagram of assembly position of each component of the detection system. (c) Schematic diagram of synchronization and analysis of landing data. (d) Curve of tensile power over time at low temperature. (e) Curve of output signal over stretch power at low temperature. (f) Output curve of underwater gel signal at 35 °C temperature difference. (g) Hydrogel output signal curve during simulated parachute descent.
小结
本文提出了一种具有优异拉伸和温度响应性能的水凝胶。该水凝胶通过将聚乙烯醇(PVA)、硼砂、三羟甲基丙烷(TA)、三氟甲烷(SF)、氯化钠(NaCl)和聚乙烯吡咯烷酮(GR)混合并搅拌的简单工艺制备而成。其特点是原料来源广泛且成本低廉。通过利用硼酸酯键与材料间形成的多个氢键的协同作用,该水凝胶实现了高拉伸倍数比(>6000%)、快速响应/恢复时间(12.5 ms/12.5 ms)及高灵敏度(GF>214,当拉伸倍数比>300%时)。此外,该水凝胶具有良好的生物相容性和优异的降解能力,符合绿色发展的理念。最后,基于其卓越的拉伸能力,作为概念验证,我们提出了将水凝胶应用于小型智能保险箱、人体运动训练及降落伞过程检测等领域的可能性,从而展示了水凝胶优异的拉伸倍数和拉伸敏感性特性。
文献:
https://doi.org/10.1016/j.snb.2025.138566
  • 可穿戴电子
  • 柔性传感器
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    四川大学、香港城市大学:研发一体化自供电可穿戴传感系统,用于多模式健康监测
      多模态传感器、能量收集和存储模块的集成促进了智能可穿戴电子产品的进步。然而,现有的模块化构建策略集成度较低,导致设备笨重,可能会影响信号采集的稳定性和可靠性。在这里,四川大学赵江琦
    的头像 发表于 04-23 19:24 153次阅读
    四川<b class='flag-5'>大学</b>、香港城市<b class='flag-5'>大学</b>:研发一体化自供电<b class='flag-5'>可穿戴</b><b class='flag-5'>传感</b>系统,<b class='flag-5'>用于</b>多模式健康监测
    柔性三防漆:适合电子产品及抗震性能解析
    柔性三防漆是一种高弹性电子保护涂层,适用于汽车电子、无人机、医疗设备、可穿戴设备振动环境
    的头像 发表于 04-07 13:39 180次阅读
    <b class='flag-5'>柔性</b>三防漆:适合<b class='flag-5'>电子产品</b>及抗震性能解析
    Allegro ACS37200电流传感器荣获真正具有创新性电子产品
    近日,Allegro ACS37200 电流传感器凭借卓越性能,成功斩获国际电子权威媒体《Electronics For You》颁发的「真正具有创新性的电子产品(Truly Innovative Electronics)」奖。
    的头像 发表于 04-02 15:11 282次阅读
    陕西科技大学:研究用于人体监测和可穿戴舒适性的全功能皮革基柔性电容式压力传感器
    智能可穿戴电子设备能够长时间连续监测生理指标,同时为用户提供舒适的佩戴体验,是医疗保健系统、人机交互和物联网的核心组件。高性能柔性传感器是智能可穿戴
    的头像 发表于 03-20 10:38 1.8w次阅读
    陕西科技<b class='flag-5'>大学</b>:研究<b class='flag-5'>用于</b>人体监测和<b class='flag-5'>可穿戴</b>舒适性的全功能皮革基<b class='flag-5'>柔性</b>电容式压力<b class='flag-5'>传感器</b>
    美国加州理工学院:可穿戴柔性传感器最新突破!
        研究背景 可穿戴和植入式生物传感器是一类新兴的健康监测技术,因其能够实现个性化、实时监测营养物质、代谢物、激素及药物循环分子,广泛应用于生理健康评估、疾病早期诊断和精准医疗
    的头像 发表于 01-26 18:36 458次阅读
    美国加州理工学院:<b class='flag-5'>可穿戴</b><b class='flag-5'>柔性</b><b class='flag-5'>传感器</b>最新突破!
    安徽农业大学: 开发石墨/聚氨酯海绵复合材料,用于柔性压力传感器和智能缓冲材料
    Cushioning  Materials”的最新研究成果,报道了在生物质基海绵柔性压力传感器方面的重要进展。 随着智能家居的普及,传统柔性传感器在灵敏度、耐用性及舒适性方面的局限性
    的头像 发表于 12-05 18:11 2283次阅读
    <b class='flag-5'>安徽</b>农业<b class='flag-5'>大学</b>: 开发<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>/聚氨酯海绵复合材料,<b class='flag-5'>用于</b><b class='flag-5'>柔性</b>压力<b class='flag-5'>传感器</b>和智能缓冲材料
    香港理工大学、南方科技大学:新型压阻式石墨/CNC声学传感器用于语音识别
      可穿戴声学传感器通过校准喉部振动并将其转化为合成语音,为语言障碍者提供了有效的沟通解决方案。本文,香港理工大学Zhongqing SU、南方科技大学周利民教授
    的头像 发表于 11-27 18:28 590次阅读
    香港理工<b class='flag-5'>大学</b>、南方科技<b class='flag-5'>大学</b>:新型压阻式<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>/CNC声学<b class='flag-5'>传感器</b>,<b class='flag-5'>用于</b>语音识别
    北京航空航天大学:基于二维材料的可穿戴生物设备—从柔性传感器到智能集成系统
    可穿戴生物设备的快速发展推动了柔性多功能材料在健康监测中的应用。将可穿戴传感器与多功能智能系统相结合,已成为远程健康监测和个性化健康管理的趋势。二维材料因其卓越的机械、电学、光学和化学
    的头像 发表于 11-04 17:07 7668次阅读
    北京航空航天<b class='flag-5'>大学</b>:基于二维材料的<b class='flag-5'>可穿戴</b>生物设备—从<b class='flag-5'>柔性</b><b class='flag-5'>传感器</b>到智能集成系统
    深圳技术大学:超薄石墨应变传感器阵列,用于毫米级分辨率的高灵敏度多功能传感
    石墨柔性传感器阵列的应用受两大限制制约:现有制备方法难以实现高空间分辨率,且缺乏面向实际应用的系统级集成方案。为应对这些挑战,本文,深圳技术大学
    的头像 发表于 10-11 18:38 6071次阅读
    深圳技术<b class='flag-5'>大学</b>:超薄<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>应变<b class='flag-5'>传感器</b>阵列,<b class='flag-5'>用于</b>毫米级分辨率的高灵敏度多功能<b class='flag-5'>传感</b>
    中科院宁波材料所:双结构石墨/PDMS复合传感器用于可穿戴设备应用
    在实际应用中,柔性传感器需要在宽广的测量范围内展现出足够高的灵敏度;然而,这种需求总是伴随着权衡取舍。本文通过对激光诱导石墨(LIG)导电路径的几何创新,解决了上述挑战。本文, 中科
    的头像 发表于 08-26 18:02 5987次阅读
    中科院宁波材料所:双结构<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>/PDMS复合<b class='flag-5'>传感器</b>,<b class='flag-5'>用于</b><b class='flag-5'>可穿戴</b>设备应用
    浙江科技大学:研发竹纤维素-石墨凝胶传感器用于健康监测、柔性可穿戴应用
    基于纤维素的空气凝胶因其互联多孔网络、低密度和优异的压缩性,特别适合用于柔性传感器,这些特性使得有效的变形检测和信号传输成为可能。然而,纤维素气凝胶
    的头像 发表于 08-20 10:22 9392次阅读
    浙江科技<b class='flag-5'>大学</b>:研发竹纤维素-<b class='flag-5'>石墨</b><b class='flag-5'>烯</b>气<b class='flag-5'>凝胶</b><b class='flag-5'>传感器</b>,<b class='flag-5'>用于</b>健康监测、<b class='flag-5'>柔性</b><b class='flag-5'>可穿戴</b>应用<b class='flag-5'>等</b>
    可穿戴系列之全息无感化健康管理传感器
    监测,彻底消除人为干预需求,实现医疗监测与日常生活的无缝整合。图1人体多模态生物信号传感分布图HUIYING可穿戴传感器总结分析穿戴传感器
    的头像 发表于 08-18 20:21 7548次阅读
    <b class='flag-5'>可穿戴</b>系列之全息无感化健康管理<b class='flag-5'>传感器</b>
    德国哥廷根大学:研发木质素/ZnO“呼吸纤维”:自供能气流传感柔性新突破
    研究背景   气流传感器在环境监测、生物医学、可穿戴设备领域应用广泛,但传统传感器存在刚性笨重、依赖外部电源、灵活性不足局限,难以满足
    的头像 发表于 08-01 18:58 933次阅读
    德国哥廷根<b class='flag-5'>大学</b>:研发木质素/ZnO“呼吸纤维”:自供能气流<b class='flag-5'>传感</b>的<b class='flag-5'>柔性</b>新突破
    国仪电镜助力PANC/T-Fe凝胶在不同环境温度下的微观结构分析
    福州大学赖跃坤教授团队针对可穿戴传感器、软机器人、组织工程和伤口敷料领域对强粘附性凝胶的迫切
    发表于 07-30 13:44
    可穿戴产品的设计挑战及解决方案
    在我们的日常生活中,可穿戴电子产品已经无处不在。相比于最初的产品,如今的可穿戴设备不再只是独立的设备,从智能手表到智能眼镜再到医疗贴片,它们正在成为人们健康生活方式的关键部分。
    的头像 发表于 06-03 14:42 3166次阅读
    <b class='flag-5'>可穿戴</b><b class='flag-5'>产品</b>的设计挑战及解决方案
