东华大学:研究基于石墨烯纤维的高性能压力传感器,具有双边致密结构,用于人体运动监测
传感器专家网 2025-09-08 17:34 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
柔性压力传感器因能精确检测外部压力并贴合复杂曲面,在健康监测与人机交互领域备受关注。然而,灵敏度、检测范围与机械稳定性之间的固有权衡严重制约了其性能提升与进一步发展。研究采用湿法纺丝与基底辅助干燥策略,通过调控石墨烯纤维(GF)的形态结构优化导电网络。最终成功制备出高导电性(3.19×10⁴ S m⁻¹)、抗拉强度达179.6 MPa、应变能力达6.5%的致密带状GF,并将其应用于柔性压力传感器的传感层。
该基石碳纤维压力传感器在0-10kPa范围内展现出30.79kPa⁻¹的高灵敏度,即使检测范围扩展至150kPa仍保持15.59kPa⁻¹的灵敏度。此外,其响应/恢复特性迅捷(88毫秒/72毫秒),经10000次循环测试仍保持优异耐久性。该传感器能有效检测关节弯曲、腕部屈曲及脉搏跳动等细微生理信号,彰显其在健康监测与智能可穿戴设备领域的应用潜力。
2图文导读
图1.Design and applications of GF. (a) Schematic diagram of GO sheet alignment. (b) Schematic diagram of the GF-based sensing layer fabrication process. (c) Cross-sectional schematic diagram of the GF. (d) Schematic diagram of the GF pressure sensor. (e) Working mechanism of the GF pressure sensor. (f) Application of the GF sensor in motion detection.
图2.(a) Cross-sectional SEM images of GF with different routes. (b) Surface SEM images of GF with different routes. (c) Simulated snapshot before solvent evaporation during substrate-assisted drying. PE substrate is shown in gray; in the GO sheets, carbon atoms are cyan, oxygen atoms red, and hydrogen atoms white; acetic acid molecules are orange, and water molecules are purple. The initial simulation box size is 8 nm × 8 nm × 9.52 nm. (d) Simulated snapshot after solvent evaporation during substrate-assisted drying. (e) Changes in interaction energies between GO-GO and GO-PE interfaces. (f) Digital photograph of GF thickness measured by mechanical methods. (g) Digital photograph of GF. (h) Digital photograph of the GOF fusion-assembled sensing layer. (i) Digital photograph of the GF sensing layer. (j) Digital photograph of the GF sensor.
图3. Microstructural characterization and DFT simulation of GF prepared via different routes. (a) XRD patterns. (b) Statistical analysis of Lc. (c) Raman spectra. (d) Statistical analysis ofID/IGand La. (e) XPS spectra before and after reduction. (f) XPS C 1s spectra before and after reduction. (g) Electrical conductivity. (h) Mechanical properties. (i) Molecular models of graphene layer stacking in two extreme modes. (j)I–Vcurve of the molecular model. (k) Transmission spectra of the molecular model at zero bias. (l) Spatial distribution of the highest occupied molecular orbital (HOMO) of the molecular model.
图4.Sensing performance tests of the GF pressure sensor. (a) Current response during pressure loading and unloading. (b)I–Vcurves under different pressure loads. (c) Sensitivity curve of the GF sensor. (d) Current signal response under different pressure loads. (e) Current signal response at different compression rates. (f) Response and recovery time. (g) Long-term durability. (h) Comparison of sensitivity and detection range with other reported pressure sensors.
图5.Application of GF sensors in human motion detection. (a) Finger pressing. (b) Different pronunciations. (c) Breath detection. (d) Elbow bending. (e) Knee bending. (f) Amplified pulse signal after walking. (g) Pulse detection after walking and running. (h) Amplified pulse signal after running.
图6.Application of GF sensors in gesture recognition and Morse code. (a) Photograph of the sensor attached to a finger. (b) Schematic diagram of input and output in the signal acquisition process. (c) Sensor response to different finger bending angles. (d) Ten hand gestures representing numbers from 1 to 10 and the corresponding signals from five fingers. (e) Morse code for “DHU” and “JXU” based on finger bending. (f) Circuit diagram of the robotic hand control system. (g) Synchronized gesture control of the robotic hand.
3小结
综上所述,成功制备了基于双面高密度玻璃纤维(GF)的高性能柔性压力传感器。通过采用湿法纺丝技术结合基板辅助干燥策略,优化了GF的形态和层间堆叠结构,从而获得了高电导率(3.19×10⁴ S m⁻¹)和优异的机械性能(抗拉强度179.6 MPa,断裂应变6.5%)。制备的GF压力传感器在0-10 kPa压力范围内展现出30.79 kPa⁻¹的超高灵敏度,当检测范围扩展至150 kPa时仍保持15.59 kPa⁻¹的高灵敏度。此外,该器件展现出快速响应/恢复特性(响应时间88毫秒/恢复时间72毫秒),并在经历10000次加载循环后仍保持稳定的传感性能。该传感器能精确捕捉人体运动信号,如指关节弯曲、喉部振动和脉搏搏动,凸显其在健康监测、智能可穿戴设备及人机交互领域的巨大潜力。本研究为柔性传感材料设计提供了新思路,为高性能压阻式传感器的开发奠定了基础。
文献:
https://doi.org/10.1016/j.jmst.2025.07.057
来源:材料分析与应用
  • 压力传感器
  • 石墨烯
  • 柔性传感器
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    如何优化气体压力传感器性能,提高传感器测量精度?
    气体压力传感器是一种用于测量气体压力的装置,其精度直接影响到工业自动化控制的效果。在生产过程中,气体压力传感器的精度越高,控制效果越好,生产效率也越高。因此,提高气体
    的头像 发表于 10-18 17:21 1193次阅读
    清华大学:鲨鱼与鳄鱼皮肤启发的高性能压力传感
    随着柔性电子、可穿戴设备、医疗监测和机器人技术的快速发展,对柔性压力传感器的需求不断增加,且性能要求愈发严苛。在众多压力传感器工作机制中,电阻式压力
    的头像 发表于 07-10 17:33 908次阅读
    清华<b class='flag-5'>大学</b>:鲨鱼与鳄鱼皮肤启发的<b class='flag-5'>高性能</b><b class='flag-5'>压力</b><b class='flag-5'>传感</b>
    浙江大学研究石墨基嗅觉传感阵列实现细菌和病毒性呼吸道感染的快速区分
    研究团队通过气敏受体调控策略构建了超灵敏高识别度的石墨的嗅觉传感器研究表明还原氧化石墨
    的头像 发表于 05-28 17:34 2361次阅读
    浙江<b class='flag-5'>大学</b>:<b class='flag-5'>研究</b><b class='flag-5'>石墨</b><b class='flag-5'>烯</b>基嗅觉<b class='flag-5'>传感</b>阵列实现细菌和病毒性呼吸道感染的快速区分
    研究用于人体足底压力和步态分析的高灵敏度压力传感器
    01 研究背景 足底压力和步态是测量人体日常生理信息的关键参数,是下肢骨骼和肌肉结构、周围神经和中枢神经系统协调运动的最终结果。 然而,由于
    的头像 发表于 04-17 16:14 926次阅读
    <b class='flag-5'>研究</b><b class='flag-5'>用于</b><b class='flag-5'>人体</b>足底<b class='flag-5'>压力</b>和步态分析的高灵敏度<b class='flag-5'>压力传感器</b>
    环型压力传感器研究和应用
    的重要元件。本文将带您深入了解环型压力传感器的原理、特点及其在各个领域的广泛应用。 一、环型压力传感器的原理与特点 环型压力传感器是一种基于应变片技术和胡克定律的测力传感器。其
    的头像 发表于 03-05 17:30 893次阅读
    环型<b class='flag-5'>压力传感器</b>的<b class='flag-5'>研究</b>和应用
    EastWave应用:光场与石墨和特异介质相互作用的研究
    图 1-1模型示意图 本案例使用“自动计算透反率模式”研究石墨和特异介质的相互作用,分析透反率在有无石墨存在情况下的变化。光源处于近红
    发表于 02-21 08:42
    研究基于密集结构石墨纤维压力传感器用于运动监测
      压阻式压力传感器因其结构简单、灵敏度高和成本低而备受关注。石墨以其出色的机械和电气性能而闻名,作为
    的头像 发表于 01-21 17:07 835次阅读
    <b class='flag-5'>研究</b>基于密集<b class='flag-5'>结构</b><b class='flag-5'>石墨</b><b class='flag-5'>烯</b><b class='flag-5'>纤维</b>的<b class='flag-5'>压力传感器</b>,<b class='flag-5'>用于</b><b class='flag-5'>运动</b><b class='flag-5'>监测</b>
    压力传感器怎么测试好坏
    压力传感器作为工业自动化和各类监测系统中的关键组件,其准确性和可靠性直接关系到整个系统的运行效率和安全性。因此,对压力传感器进行准确的测试,以判断其性能和状态,是确保系统稳定运行的重要
    的头像 发表于 12-26 18:46 3248次阅读
    <b class='flag-5'>压力传感器</b>怎么测试好坏
    压力传感器的特点和优势 水压力传感器的校准方法
    压力传感器的特点和优势 1. 高精度 水压力传感器通常具有高精度,能够准确测量微小的压力变化,这对于需要精确控制压力的应用场景至关重要。
    的头像 发表于 12-12 15:05 1343次阅读
    高精度压力传感器应用领域 高精度压力传感器使用注意事项
    高精度压力传感器应用领域 1. 工业自动化 高精度压力传感器在工业自动化中扮演着重要角色,尤其是在过程控制和监测方面。它们可以用于监测和控制
    的头像 发表于 12-12 14:40 1471次阅读
    如何利用气体压力传感器监测气体泄漏
    在化工、石油、天然气等行业中,气体泄漏可能导致严重的安全事故和环境污染。因此,及时准确地监测气体泄漏对于保障人员安全和环境保护至关重要。气体压力传感器作为一种有效的监测工具,能够通过检测压力
    的头像 发表于 12-09 18:03 1742次阅读
    气体压力传感器的数据采集与分析
    气体压力传感器是工业和科研领域中常用的一种传感器用于检测和测量气体的压力。随着技术的发展,气体压力传感器的应用范围越来越广泛,包括环境
    的头像 发表于 12-09 16:31 2211次阅读
    气体压力传感器的种类和特点 气体压力传感器在环保监测中的应用
    气体压力传感器的种类和特点 气体压力传感器是一种用于检测气体压力的仪器,广泛应用于各种工业和环境监测
    的头像 发表于 12-09 16:25 2404次阅读
    气体压力传感器与液体压力传感器的区别
    有所不同。 工作原理 气体压力传感器 气体压力传感器通常用于测量气体的压力。它们可以基于不同的物理原理工作,如压电效应、应变效应或电容效应。在压电效应中,
    的头像 发表于 12-09 16:23 1586次阅读
    气体压力传感器工作原理解析 气体压力传感器在工业应用中的作用
    气体压力传感器工作原理解析 1. 压力传感器的基本概念 压力传感器是一种将压力信号转换成电信号的装置。它可以测量绝对压力、差压或表
    的头像 发表于 12-09 16:19 2974次阅读
