LM393 是双电压比较器集成电路。
输出负载电阻能衔接在可允许电源电压范围内的任何电源电压上,不受 Vcc端电压值的限制.此输出能作为一个简单的对地SPS开路(当不用负载电阻没被运用),输出部分的陷电流被可能得到的驱动和器件的β值所限制.当达到极限电流(16mA)时,输出晶体管将退出而且输出电压将很快上升。
The LM393 series are dual independent precision voltage comparators capable of single or split supply operation. These devices are designed to permit a common mode range-to-ground level with single supply operation. Input offset voltage specifications as low as 2.0 mV make this device an excellent selection for many applications in consumer automotive and industrial electronics.
Wide Single-Supply Range: 2.0 Vdc to 36 Vdc
Split-Supply Range: +/-1.0 Vdc to +/-18 Vdc
Very Low Current Drain Independent of Supply Voltage: 0.4 mA
Low Input Bias Current: 25 nA
Low Input Offset Current: 5.0 nA
Low Input Offset Voltage: 2.0 mV (max) LM393A 5.0 mV (max) LM293/393
Input Common Mode Range to Ground Level
Differential Input Voltage Range Equal to Power Supply Voltage
Output Voltage Compatible with DTL, ECL, TTL, MOS, and CMOS Logic Levels
ESD Clamps on the Inputs Increase the Ruggedness of the Device without Affecting Performance
该电路的特点如下:
工作温度范围:0°C -- +70°C
SVHC(高度关注物质):No SVHC (18-Jun-2010)
器件标号:393
工作电源电压范围宽,单电源、双电源均可工作,单电源: 2~ 36V, 双电源:±1~±18V;
消耗电流小, ICC=0.4mA;
输入失调电压小, VIO=±2mV;
共模输入电压范围宽, VIC=0~VCC-1.5V;
输出与TTL,DTL,MOS,CMOS 等兼容;
输出可以用开路集电极连接“或”门;
表面安装器件:表面安装
[ img]
