深入解析TPS54678EVM - 155评估模块:从原理到应用
在电子工程领域,电源管理模块的性能和稳定性至关重要。今天,我们就来深入探讨德州仪器(Texas Instruments)的TPS54678EVM - 155 6 - A,SWIFT™ 调节器评估模块。
文件下载:TPS54678EVM-155.pdf
一、模块概述
TPS54678EVM - 155评估模块主要用于评估TPS54678这款dc/dc转换器。TPS54678能够从2.95 V至6 V的输入电压源提供高达6 A的输出电流,绝对最大输入电压为7 V。该评估模块展示了使用TPS54678调节器设计时实现的小印刷电路板面积优势。其开关频率外部设定为标称500 kHz,内部集成了高端和低端MOSFET以及栅极驱动电路,MOSFET的低漏源导通电阻使得模块能够实现高效率,并在高输出电流时保持较低的结温。补偿组件位于集成电路外部,通过外部分压器可实现输出电压的可调,同时还提供可调的软启动和欠压锁定输入。
1.1 输入电压和输出电流范围
| EVM | INPUT VOLTAGE RANGE | OUTPUT CURRENT RANGE |
| TPS54678EVM - 155 | V IN = 3 V to 6 V | 0 A to 6 A |
1.2 性能规格总结
| 在输入电压 (V_{IN}=5V) 、输出电压为1.2 V(除非另有说明),环境温度为25°C(除非另有注明)的条件下,该评估模块的性能规格如下: | PARAMETER | TEST CONDITIONS | MIN | TYP | MAX | UNITS | |
| INPUT CHARACTERISTICS | |||||||
| Operating voltage range | 3 | 5 | 6 | V | |||
| V IN start voltage | V | ||||||
| V IN stop voltage | V | ||||||
| OUTPUT CHARACTERISTICS | |||||||
| Output voltage, V OUT | Output current = 0 to 6A | 1.2 | V | ||||
| Output load current, I OUT1 | I OUT_min to I OUT_max | 0 | 6 | A | |||
| Output voltage regulation | Line Regulation: Input voltage = 3 V to 6 V | 0.5% | |||||
| Load Regulation: Output current = 0 A to I OUT_max | 0.5% | ||||||
| Transient response | Peak voltage I OUT = 3 A to 6 A and | 60 | mV | ||||
| 6 A to 3 A | Recovery time | 200 | µs | ||||
| Output voltage ripple | V IN = 5 V, I OUT = 6 A | mVpp | |||||
| Output over current | 10 | A | |||||
| SYSTEMS CHARACTERISTICS | |||||||
| Switching frequency | F SW | 500 | kHz | ||||
| Control loop bandwidth | V IN = 3.3 V, I O = 6 A | kHz | |||||
| Phase Margin | V IN = 3.3 V, I O = 6 A | Degrees | |||||
| Input ripple voltage | mVp - p | ||||||
| Soft start time | mSec | ||||||
| Peak efficiency | V IN = V, I OUT = A | % | |||||
| Full load efficiency | V IN = V, I OUT = 6 A | % | |||||
| Operating temperature | T oper | 25 | ºC |
二、模块修改
2.1 输出电压设定点
| 通过改变电阻R9的值可以改变评估模块的输出电压。计算公式为: [R 9=R 10 timesleft(frac{V_{OUT }}{0.6 V}-1right)] 其中R10使用10.0 kΩ。以下是一些常见输出电压对应的R9和R10值: | R9 Ideal | R9 Actual (E96) | R10 | V OUT Ideal | V OUT Actual |
| 0 | 0 | 10.0E + 3 | 0.60 | 0.60 | |
| 3.33E + 3 | 3.32E + 3 | 10.0E + 3 | 0.80 | 0.80 | |
| 6.67E + 3 | 6.65E + 3 | 10.0E + 3 | 1.00 | 1.00 | |
| 10.00E + 3 | 10.00E + 3 | 10.0E + 3 | 1.20 | 1.20 | |
| 13.33E + 3 | 13.30E + 3 | 10.0E + 3 | 1.40 | 1.40 | |
| 16.67E + 3 | 16.50E + 3 | 10.0E + 3 | 1.60 | 1.59 | |
| 20.00E + 3 | 20.00E + 3 | 10.0E + 3 | 1.80 | 1.80 | |
| 23.33E + 3 | 23.20E + 3 | 10.0E + 3 | 2.00 | 1.99 | |
| 26.67E + 3 | 26.70E + 3 | 10.0E + 3 | 2.20 | 2.20 | |
| 30.00E + 3 | 30.10E + 3 | 10.0E + 3 | 2.40 | 2.41 | |
| 33.33E + 3 | 33.20E + 3 | 10.0E + 3 | 2.60 | 2.59 | |
| 36.67E + 3 | 36.50E + 3 | 10.0E + 3 | 2.80 | 2.79 |
2.2 软启动时间
软启动时间可通过改变C7的值进行调整,计算公式为: [Css (nF)=3 × Tss (ms)] 评估模块上C7默认设置为0.01 μF,对应的软启动时间为3.33 ms。
2.3 可调欠压锁定(UVLO)
| 欠压锁定(UVLO)可通过外部的R1和R2进行调整。评估模块使用 (R 1 = 47.5 k Omega) 和 (R 2 = 35.7 k Omega) 设定启动电压为2.88 V,停止电压为2.57 V。确定UVLO性能的参数如下: | Parameter | Value |
| Enable Pin Current when OFF | 700 nA | |
| Enable Pin Current when ON | 2.8 µA + 700 nA | |
| Enable Pin Turn ON Threshold | 1.3 V | |
| Enable Pin Turn OFF Threshold | 1.18 V |
可使用以下公式计算不同启动和停止电压所需的电阻值: [I{R 2 ON}=frac{1.30}{R{2}}] [I{R 1 O N}=I{R 2 O N}-700 n=frac{left(V{O N}-1.30right)}{R{1}}]
三、测试设置与结果
3.1 输入/输出连接
| 评估模块配备了输入/输出连接器和测试点。需要使用能够提供3 A的电源通过一对20 AWG电线连接到J1,负载通过一对20 AWG电线连接到J2,负载的最大电流能力至少为6 A。测试点TP1用于监测 (V_{IN}) 输入电压,TP2作为接地参考;TP8用于监测输出电压,TP9作为接地参考。 | Reference Designator | Function |
| J1 | Input voltage | |
| J2 | Access to track function | |
| J3 | Output voltage | |
| JP1 | 2 - pin header for enable. Connect EN to ground to disable, open to enable. | |
| JP2 | 2 - pin header allowing pull up of PWRGD to V IN. | |
| TP1 | V IN +VE | |
| TP2 | V IN –VE | |
| TP3 | SS pin | |
| TP4 | Switch node, copper dot | |
| TP5 | Power Good pin | |
| TP6 | AGND reference | |
| TP7 | Bode injection point, input voltage | |
| TP8 | V OUT +VE | |
| TP9 | V OUT –VE | |
| TP10 | Bode injection point, output voltage |
3.2 效率
评估模块的效率在负载电流约为1 A至2 A时达到峰值,随后随着负载电流接近满载而降低。在较高环境温度下,由于内部MOSFET的漏源电阻 (DS ON) 随温度变化,效率可能会降低。
3.3 输出电压调节
包括负载调节和线路调节。负载调节展示了输出电流变化时输出电压的稳定性,线路调节则体现了输入电压变化时输出电压的稳定性。
3.4 负载瞬态响应
当负载电流在0%至50%最大额定负载之间变化(输入电压为3.0 V)时,评估模块能够做出响应,总峰 - 峰电压变化如相关测试图所示。
3.5 环路特性
通过增益和相位图展示了在 (V_{IN}) 电压为5 V、负载电流为6 A时的环路响应特性。
3.6 输出电压纹波和输入电压纹波
分别展示了在不同输入电压和满载(6 A)情况下的输出电压纹波和输入电压纹波,纹波电压直接在输出电容和输入电容两端测量。
3.7 启动和关闭
启动过程中,输出电压会根据输入电压达到UVLO阈值或使能信号达到阈值而上升;关闭过程中,输出电压会根据输入电压低于UVLO停止阈值或使能信号接地而下降。
3.8 打嗝模式电流限制
当峰值开关电流超过电流限制阈值时,TPS54678会进入打嗝模式,即设备关闭并重新启动。当输出短路到地时,设备会持续复位,直到故障条件消除。
四、电路板布局
评估模块的电路板布局采用了典型的用户应用方式。顶层和底层为2 - oz铜,两个内层为1 - oz铜。顶层包含 (V{IN}) 、 (V{OUT}) 和 (PHASE) 的主要电源走线,以及TPS54678其余引脚的连接和大面积的接地区域。底层和内层仅包含接地平面。顶层接地区域通过多个过孔与底层和内层接地平面连接,包括TPS54678器件正下方的四个过孔,以提供从顶层接地区域到底层和内层接地平面的热路径。输入去耦电容和自举电容尽可能靠近集成电路放置,电压设定点电阻分压器组件也靠近集成电路,电压分压器网络连接到输出连接器附近的 (V_{OUT}) 铜走线。此外,还包含一个额外的输入大容量电容C16,以提供更低的源阻抗。
五、原理图和物料清单
5.1 原理图
提供了评估模块的详细原理图,可用于深入分析电路原理和信号流向。
5.2 物料清单
| 列出了评估模块中使用的所有元器件,包括电容、电阻、电感、连接器、集成电路等的详细信息,方便进行元器件的替换和采购。 | RefDes | Value | Description | Size | Part Number | MFR |
| C4, C8 | 0.1 µF | Capacitor, ceramic, 50 V, X5R, 10% | 603 | Std | Std | |
| C5 | Open | Capacitor, ceramic | 603 | Std | Std | |
| C6 | 2200 pF | Capacitor, ceramic, 50 V, X7R, 10% | 603 | Std | Std | |
| C7 | 0.01 µF | Capacitor, ceramic, 25 V, X7R, 10% | 603 | Std | Std | |
| C14 | 220 pF | Capacitor, ceramic, 50 V, C0G, 5% | 603 | Std | Std | |
| C15 | 150 pF | Capacitor, ceramic, 50 V, C0G, 5% | 603 | Std | Std | |
| C1 - 3 C9 - 13 | 47 µF | Capacitor, ceramic, 10 V, X5R, ±20% | 1206 | Std | Std | |
| C16 | 220 µF | Capacitor, Electrolytic, SMT, 50 VDC | 0.457 × 0.406 | EEE - FK1H221P | Panasonic | |
| JP1 - 2 - 3 | PEC02SAAN | Header, Male 2 - pin, 100mil spacing | 0.100 in × 2 | PEC02SAAN | Sullins | |
| L1 | 1.2 µH | Inductor, SMD Shielded Power, 11.8 A, 7.4 m Ω | 5.3 × 5.5 mm | XAL5030 - 122ME | Coilcraft | |
| R1 | 14.7 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R2 | 12.7 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R3 | 26.7 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R4 | 82.5 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R5 - 6 | Open | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R7 | 100 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R8 | 51.1 Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| R9, R10 | 20.0 k Ω | Resistor, chip, 1/10W, 1% | 603 | Std | Std | |
| J1 J3 | ED555/2DS | Terminal Block, 2 - pin, 6 - A, 3.5 mm | 0.27 × 0.25 in | ED555/2DS | OST | |
| TP1 TP3 TP5 - 8 TP10 | 5000 | Test Point, Red, Thru Hole Color Keyed | 0.100 × 0.100 in | 5000 | Keystone | |
| TP2 TP9 | 5001 | Test Point, Black, Thru Hole Color Keyed | 0.100 × 0.100 in | 5001 | Keystone | |
| U1 | TPS54678RTE | IC, 3 - V to 6 - V Input, 6 - A Output, 2 MHz, Sync. Step - Down Switcher With Integrated FET | QFN | TPS54678RTE | TI | |
| Label | Label | 1.25 × 0.25 in | THT - 13 - 457 - 10 | Brady |
六、注意事项
使用该评估模块时,用户需承担妥善安全处理设备的全部责任和义务,并对因设备处理或使用产生的所有索赔进行赔偿。若评估板不符合用户指南中的规格,可在交付日期起30天内退还以获得全额退款。同时,模块可能受到联邦通信委员会(FCC)和加拿大工业部(IC)规则的约束,使用时需遵循相关规定。此外,在日本使用该产品时,需遵守日本电波法的相关要求。
评估模块
1834浏览量
8387 -
电源管理模块
40浏览量
9982
