ADF4372 Microwave Wideband Synthesizer with Integrated VCO
数据:
优势和特点
  • RF output frequency range: 62.5 MHz to 16,000 MHz
  • Fractional-N synthesizer and integer-N synthesizer
  • High resolution 39-bit fractional modulus
  • Typical PFD Spurious -100 dBc
  • Integrated RMS Jitter < 40 fs (1 kHz – 100 MHz)
  • Normalized Phase Noise Floor (FOM) -234 dBc/Hz
  • Phase frequency detector (PFD) operation to 250 MHz
  • Reference frequency operation to 600 MHz
  • Maintains frequency lock over −40°C to +105°C
  • Low phase noise, voltage controlled oscillator (VCO)
  • Programmable divide by 1, 2, 4, 8, 16, 32, or 64 output
  • 0.06 -8 GHz output at RF8
  • 0.06 - 8 GHz output at RFAUX8
  • 8 -16 GHz output at RF16
  • Analog and digital power supplies: 3.3 V
  • VCO power supply +5V
  • Integrated low dropout regulator (LDO)
  • Programmable output power level
  • RF output mute function
  • 7mm × 7mm 48 Lead LGA Package
产品详情
The ADF4372 allows implementation of fractional-N or integer-N phase-locked loop (PLL) frequency synthesizers when used with an external loop filter and an external reference frequency. The wideband microwave VCO design allows frequencies from 62.5 MHz to 16 GHz to be generated.
The ADF4372 has an integrated VCO with a fundamental output frequency ranging from 4000 MHz to 8000 MHz In addition, the VCO frequency is connected to divide by 1, 2, 4, 8, 16, 32, or 64 circuits that allow the user to generate RF output frequencies as low as 62.5 MHz at RF8. A frequency multiplier at RF16 generates from 8 – 16 GHz. RFAUX8 duplicates the frequency range of RF8, or permits direct access to the VCO Output. To suppress the unwanted products of frequency multiplication, a harmonic filter exists between the multipliers and the output stages of RF16 and.
Control of all on-chip registers is through a simple 3-wire interface. The ADF4372 operates with analog and digital power supplies ranging from 3.15 V to 3.45 V, and +5V for the VCO power supply. The ADF4372 also contains hardware and software power-down modes.
方框图
技术文档
数据手册(1)
元器件购买 ADF4372 相关库存
相关阅读
