TPS51218是一款小型单降压控制器,具有自适应导通时间D-CAP™模式。该器件适用于数字消费类产品中的低输出电压,高电流,PC系统电源轨和类似的负载点(POL)电源。采用最小引脚数的小型封装可节省PCB空间,而专用EN引脚和预设频率选择可最大限度地减少新设计所需的设计工作量。轻载条件下的跳跃模式,强栅极驱动器和低侧FET R DS(on)电流检测在宽负载范围内支持低损耗和高效率。转换输入电压是高端FET漏极电压,范围为3 V至28 V,输出电压范围为0.7 V至2.6 V.该器件需要外部5 V电源。 TPS51218采用10引脚SON封装,额定温度范围为-40°C至85°C。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| TPS51218 | TPS51117 | TPS51217 |
| 3 | 1.8 | 3 |
| 28 | 28 | 28 |
| 0.7 | 0.76 | 0.6 |
| 2.6 | 5.5 | 2.6 |
| 20 | 10 | 20 |
| 1 | 1 | 1 |
| 1 | 1 | 1 |
| 266 | 100 | 312 |
| 465 | 550 | 368 |
| 0.32 | 0.4 | 0.32 |
| Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Power Good Pre-Bias Start-Up Synchronous Rectification | Dynamic Voltage Scaling Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification |
| 91 | 95 | 89 |
| -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog |
| WSON | TSSOP VQFN | WSON |
| D-CAP | D-CAP | D-CAP |
