LM2854 PowerWise™降压转换器是一款500kHz或1MHz降压开关稳压器,能够驱动高达4A的负载,并且拥有出色的电源转换效率,线路和负载调节性能以及输出精度.LM2854的输入电压轨范围为2.95V至5.5V,提供的高精度可调节输出电压低至0.8V。可通过外部小电容实现软启动,以便控制启动过程,从而使LM2854能够正常进入预偏置输出电压。部分内部补偿功能减少了外部无源组件数以及电压模式降压转换器应用中通常所需的PCB电路板空间,同时仍然能够灵活处理陶瓷和/或电解电容。该器件采用无损逐周期峰值电流限制为负载提供过流或短路故障保护,并通过使能比较器来简化电源排序进行了优化.LM2854采用外露焊盘HTSSOP-16封装,提升了稳压器的散热性能。
所有商标均为他们各自的主人。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM2854 | LM20124 | LM2853 |
| 2.95 | 2.95 | 3 |
| 5.5 | 5.5 | 5.5 |
| 0.8 | 0.8 | 0.8 |
| 5 | 5 | 3.3 |
| 4 | 4 | 3 |
| 1 | 1 | 1 |
| 500 | 1000 | 550 |
| 1000 | 1000 | 550 |
| 1.7 | 3.5 | 0.85 |
| Enable Synchronous Rectification Tracking | Enable Power Good Pre-Bias Start-Up Synchronous Rectification Tracking | Enable Synchronous Rectification Tracking |
| Voltage Mode | Current Mode | Voltage Mode |
| 100 | 85 | 100 |
| -40 to 85 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP |
