TPS23880是一款8通道供电设备(PSE)控制器,旨在按照IEEE 802.3bt(草案)标准向以太网电缆提供电力。 8个单独的功率通道能够以2线对(1通道)或4线对(2通道)PoE端口的方式进行任意组合配置.PSE控制器可以检测具有某一有效特征的受电设备(PD),根据其分类确定器件的电源要求并进行供电。
可编程SRAM支持通过I2C实现现场固件可升级性,从而确保与支持最新PoE器件的最大互操作性。外部FET架构可帮助设计人员平衡尺寸,效率,散热和解决方案成本要求。可编程端口电源限制可在整个工作电压范围内提供稳定的电源限制,并且准确的遥测可确保可靠的系统级电源管理控制。 OSS)输入可以为要求立即禁用多个端口的应用提供多达八个级别的逐端口关断。
端口重映射和与TPS2388的引脚对脚兼容性可轻松实现上一代PSE设计的迁移,并支持可互换2层PCB设计以适应不同系统的PoE电源配置。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| ICUT |
| ILIM |
| PoE Standards Supported |
| FET |
| MPS Method |
| Pair Control |
| Operating Temperature Range (C) |
| No. of PSE Ports |
| Features |
| Pin/Package |
| TPS23880 | TPS23861 | TPS2388 |
| 44 | 44 | 44 |
| 57 | 57 | 57 |
| Programmable | Programmable | Programmable |
| 802.3at Type 1 (802.3af) 802.3at Type 2 802.3bt Type 3 802.3bt Type 4 | 802.3at Type 1 (802.3af) 802.3at Type 2 | 802.3at Type 1 (802.3af) 802.3at Type 2 |
| External | External | External |
| DC Disconnect | DC Disconnect | DC Disconnect |
| 2-Pair Alt A 4-Pair | 2-Pair Alt A | 2-Pair Alt A |
| -40 to 125 | -40 to 125 | -40 to 125 |
| 8 | 4 | 8 |
| Auto Mode Current Limit with Foldback Fast shutdown Multi Level Port Priority Over Current Reporting Over Temp Reporting Port remapping Programmable Port Power Limiting SRAM Programmable | Autonomous Mode Current Limit with Foldback Fast shutdown Over Current Reporting Over Temp Reporting | Current Limit with Foldback Fast shutdown Multi Level Port Priority Over Current Reporting Over Temp Reporting Port remapping |
| 56QFN | 28TSSOP | 56QFN |
