这个器件包含一个单电压比较器,此比较器被设计成在宽范围电压上由一个单电源供电运行。如果两个电源之间的电压差在2V和36V之间且V CC 比输入共模电压的正值至少高1.5V,也可使用双电源供电运行。电流漏极与电源电压无关。为了实现线与关系,用户可将输出连接至另外一个集电极开路输出。
| Number of Channels (#) |
| Output Type |
| Vs (Min) (V) |
| Vs (Max) (V) |
| Propagation Delay Time (uS) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Max) (mA) |
| Input Bias Current (+/-) (Max) (nA) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| VICR (Max) (V) |
| VICR (Min) (V) |
| TL331-EP | TL331 | TL331-Q1 | TL712 | TL714 |
| 1 | 1 | 1 | 1 | 1 |
| Open Collector | Open Collector | Open Collector | Push-Pull | Push-Pull |
| 2 | 2 | 2 | 4.75 | 4.75 |
| 36 | 36 | 36 | 5.25 | 5.25 |
| 0.3 | 0.3 | 0.3 | 0.025 | 0.006 |
| 5 | 5 | 5 | 5 | 10 |
| 0.7 | 0.7 | 0.7 | 20 | 12 |
| 250 | 250 | 250 | 600000 | 600000 |
| Out | Out | Out | In | No |
| N/A | N/A | N/A | Hysteresis Strobe | Hysteresis |
| HiRel Enhanced Product | Catalog | Automotive | Catalog | Catalog |
| -55 to 125 | -40 to 105 -40 to 85 | -40 to 125 -40 to 85 | 0 to 70 | 0 to 70 |
| SOT-23 | SOT-23 | SOT-23 | PDIP SO SOIC TSSOP | PDIP SOIC |
| 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SO: 48 mm2: 7.8 x 6.2(SO) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 34.5 | 34.5 | 34.5 | 5.5 | 3.6 |
| 0 | 0 | 0 | 0 | 1.4 |
