RS-485端口用ESD静电防护器件:SM712
东沃电子 2023-05-08 16:18 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
搜“SM712”这个型号物料,会发现,客户还经常搜:SM712是什么二极管、SM712参数、SM712产品手册、SM712厂家、SM712现货、SM712价格、SM712封装、SM712封装尺寸、SM712应用、SM712静电防护器件可以用在RS-485接口上吗?不同的客户,会碰到不同的问题。SM712这颗常用型号ESD静电防护器件,其实很多新老电子工程师都非常熟悉的,甚至比东沃电子(DOWOSEMI)专业生产ESD二极管还专业。接下来,二极管厂家东沃电子(DOWOSEMI)针对SM712为您详细展开介绍一下!
查阅东沃电子“ESD-SM712 Datasheet”产品手册可知:
1)ESD静电防护器件SM712特性
√ Protects two -7V to 12V lines
√ Low capacitance
√ Low clamping voltage
√ Solid-state silicon avalanche technology
√ IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
√ IEC 61000-4-4 (EFT) 40A (5/50ns)
√ IEC 61000-4-5 (Lightning) 12A (8/20μs)
2)ESD静电防护器件SM712参数
√ 峰值脉冲功率Peak Pulse Power ( tp =8/20μs): 400W
√ 峰值脉冲电流Peak Pulse Current ( tp =8/20μs): 12A
√ 工作电压Reverse Stand-Off Voltage: 12V和7V
√ 击穿电压Reverse Breakdown Voltage: 13.3V和7.5V
√ 钳位电压Clamping Voltage: 26V
√ 漏电流Reverse Leakage Current: 1uA
√ 结电容Junction Capacitance: 45pF 75pF
√ 封装Package: SOT-23
3)ESD静电防护器件SM712应用
EIA RS-485 specifies a ±7V ground difference between devices on the bus. This permits the bus voltage to range from +12V (5V + 7V) to -7V (0 - 7V). The SM712 is designed to protect two RS-485 data lines in extended common mode applications. The SM712 may be used to protect devices from transient voltages resulting from ESD, EFT, and lightning. The device is designed with asymmetrical operating voltages for optimum protection. The TVS diodes at pins 1 and 2 have a working voltage of 12 volts. These pins are connected to the differential data line pairs. The TVS diodes at pin 3 have a working voltage of 7 volts. Pin 3 is connected to ground. The internal TVS diodes of the SM712 will protect the transceiver input from positive transient voltage spikes greater than 12V and Negative spikes greater than 7V. A series current limiting resistor may be added in applications requiring enhanced surge immunity.
由此可知,SM712是RS-485接口常用的静电ESD防护器件,也是客户常咨询的ESD二极管。关于SM712的价格、现货、交期等其他方面的问题,可以咨询东沃电子销售工程师
  • ESD
    ESD
  • 静电
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    中科银河芯GXA3485高防护高速RS-485/RS-422收发器介绍
    在工业自动化、智能仪表、能源物联网等多领域硬件通信场景中,RS-485/RS-422总线通信的稳定性直接决定系统整体运行效能,静电干扰、多节点适配难等痛点一直是行业亟待解决的问题。作为总线通信的核心
    的头像 发表于 04-08 10:59 382次阅读
    中科银河芯GXA3485高<b class='flag-5'>防护</b>高速<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422收发器介绍
    ESD静电二极管SM712为什么能用485端口之上呢?
    RS-485接口往往需要工作在恶劣的电磁环境下,还要求实现长距离数据传输(可以达到1200米)、高速(可以达到几十Mbps)。在实际的工业、电力、自动化及仪器仪表应用中,RS-485总线标准
    的头像 发表于 12-19 23:10 642次阅读
    <b class='flag-5'>ESD</b><b class='flag-5'>静电</b>二极管<b class='flag-5'>SM712</b>为什么能用<b class='flag-5'>485</b><b class='flag-5'>端口</b>之上呢?
    抗噪能手:THVD14xx系列RS-485收发器的设计与应用
    的THVD14xx系列3.3V至5V RS-485收发器,凭借其出色的特性和性能,成为了工业通信领域的理想选择。 文件下载: thvd1410.pdf 特性亮点 抗噪与ESD保护 THVD14xx系列
    的头像 发表于 12-18 10:15 510次阅读
    芯佰微CBM3085 RS-485/RS-422 收发器:低功耗抗扰先锋
    在工业控制、远程监测等场景中,RS-485总线的长距离传输常受EMI干扰、静电冲击、功耗冗余三大难题困扰。芯佰微电子CBM3085以“低功耗+高防护”双核心设计,为工业通信提供极简解决方案,且在封装
    的头像 发表于 10-24 14:55 3375次阅读
    芯佰微CBM3085 <b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422 收发器:低功耗抗扰先锋
    基于上海贝岭产品的RS-485隔离电路方案
    RS-485是目前广泛应用的有线接口之一,其平衡的差分信号传输特性可抑制噪声,使其能在嘈杂的工作环境中实现较远距离的通信。包括电能表、工厂自动化、电机控制、白色家电、光伏储能等系统中,RS-485都是常见的通信接口。
    的头像 发表于 10-15 16:10 1826次阅读
    基于上海贝岭产品的<b class='flag-5'>RS-485</b>隔离电路方案
    【应用】XBLW MAX485:10Mbps半双工RS485收发器,高ESD防护与低功耗设计
    文章前言芯伯乐(XBLW)MAX485是一款支持3V~5.5V宽电压供电、具备±15kVESD防护能力的半双工RS485通信收发器。该器件
    的头像 发表于 09-30 20:02 713次阅读
    【应用】XBLW MAX<b class='flag-5'>485</b>:10Mbps半双工<b class='flag-5'>RS485</b>收发器,高<b class='flag-5'>ESD</b><b class='flag-5'>防护</b>与低功耗设计
    SOT-23塑料封装ESD保护二极管SM712系列规格书
    SM712瞬态电压抑制(TVS)二极管专为多点数据传输标准RS-485应用中的非对称(12V至-7V)保护而设计。该器件可用于防护静电放电(
    发表于 07-08 09:43 0次下载
    上海贝岭发布RS-485接口芯片BL3085(I4B)
    针对上述应用,上海贝岭推出了具有超强ESD保护能力的RS-485接口芯片BL3085(I4B),该芯片总线端口ESD保护能力高达±30kV(IEC 61000-4-2,接触放电),能够
    的头像 发表于 06-19 15:26 3065次阅读
    上海贝岭发布<b class='flag-5'>RS-485</b>接口芯片BL3085(I4B)
    Analog Devices / Maxim Integrated MAX33048E RS-485/RS-422收发器数据手册
    Analog Devices MAX33048E RS-485/RS-422具有灵活、简单的设计,采用3.3V或5V电源轨。MAX33048E器件为恶劣电气环境中的应用提供增强保护。所有驱动器输出和输入受到高
    的头像 发表于 06-12 15:30 1383次阅读
    Analog Devices / Maxim Integrated MAX33048E <b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422收发器数据手册
    MAX14949 500kbps半双工、RS-485/RS-422收发器技术手册
    MAX14949为一颗隔离型RS-485/RS-422收发器,为器件的电缆侧(RS-485驱动器/接收器侧)和UART侧之间提供5000V~RMS~ (60s)电隔离。对于那些
    的头像 发表于 06-04 09:17 2198次阅读
    MAX14949 500kbps半双工、<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422收发器技术手册
    MAX14946 500kbps半双工、RS-485/RS-422收发器技术手册
    MAX14946为隔离型RS-485/RS-422收发器,为器件的电缆侧(RS-485/RS-422驱动器/接收器侧)和UART侧之间提供2
    的头像 发表于 06-03 16:35 2055次阅读
    MAX14946 500kbps半双工、<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422收发器技术手册
    MAX14948 500kbps全双工RS-485/RS-422收发器,具有±30kV ESD保护技术手册
    MAX14948为隔离型RS-485/RS-422收发器,在器件的电缆侧(RS-485/RS-422驱动器/接收器侧)和UART侧之间提供5
    的头像 发表于 06-03 15:28 1415次阅读
    MAX14948 500kbps全双工<b class='flag-5'>RS-485</b>/<b class='flag-5'>RS</b>-422收发器,具有±30kV <b class='flag-5'>ESD</b>保护技术手册
    MAX14941/MAX14942 20Mbps半双工PROFIBUS/RS-485收发器技术手册
    MAX14941/MAX14942为隔离型RS-485/PROFIBUS-DP收发器,为器件的电缆侧(RS-485驱动器/接收器侧)和UART侧之间提供5000V~RMS~ ( (60s)电隔离
    的头像 发表于 06-03 15:14 1221次阅读
    MAX14941/MAX14942 20Mbps半双工PROFIBUS/<b class='flag-5'>RS-485</b>收发器技术手册
    MAX14938/MAX14939 20Mbps半双工PROFIBUS/RS-485收发器技术手册
    MAX14938/MAX14939为隔离型RS-485/PROFIBUS-DP收发器,为器件的电缆侧(RS-485驱动器/接收器侧)和UART侧之间提供2750V~RMS~ (60s)电隔离。对于
    的头像 发表于 06-03 14:56 1359次阅读
    MAX14938/MAX14939 20Mbps半双工PROFIBUS/<b class='flag-5'>RS-485</b>收发器技术手册
    时源芯微ESD防护ANT静电防护方案
    时源芯微专业EMC/EMI/EMS整改  EMC防护器件 这张电路图展示了一个IEC 61000-4-2 ANT静电防护方案,该方案旨在保护电路免受
    的头像 发表于 05-09 16:08 1079次阅读
    时源芯微<b class='flag-5'>ESD</b><b class='flag-5'>防护</b>ANT<b class='flag-5'>静电</b><b class='flag-5'>防护</b>方案
