HMC1160 MMIC VCO with Half Frequency Output, 8.45 GHz to 9.30 GHz
数据:
优势和特点
  • Dual output: fO = 8.45 GHz to 9.3 GHz
  • fO/2 = 4.225 GHz to 4.65 GHz
  • POUT: 12 dBm
  • Phase noise: −116 dBc/Hz at 100 kHz
  • No external resonator needed
  • RoHS compliant, 5 mm × 5 mm SMT package: 25 mm²
产品详情
The HMC1160 is a MMIC voltage controlled oscillator that integrates a resonator, a negative resistance device, and a varactor diode, and features a half frequency output.
Because of the monolithic construction of the oscillator, output power and phase noise performance are excellent over temperature.
Power output is 12 dBm typical from a 5 V supply voltage. The voltage controlled oscillator is housed in a RoHS compliant SMT package and requires no external matching components.
Applications
  • Point to point and multipoint radio
  • Test equipment and industrial controls
  • VSAT
方框图
技术文档
数据手册(1)
元器件购买 HMC1160 相关库存
