LM5039半桥控制器/栅极驱动器包含使用具有线电压馈电的电压模式控制实现半桥拓扑功率转换器所需的所有功能 - 前锋。 LM5039是LM5035B半桥PWM控制器的功能变体,具有过载事件期间的平均电流限制,可平衡半桥电容分压器的中心点。浮动高侧栅极驱动器能够在高达105V的电源电压下工作。高侧和低侧栅极驱动器都能够达到2A峰值。内置高压启动稳压器,以及可编程线路欠压锁定(UVLO)。振荡器采用单个电阻编程,频率高达2MHz。振荡器也可以与外部时钟同步。电流检测输入提供逐周期峰值和平均电流限制。其他功能包括可调节打嗝模式过载保护,软启动,修正参考和热关断。
所有商标均为各自所有者。
| Topology |
| Control Method |
| Vin (Min) (V) |
| Vin (Max) (V) |
| Frequency (Max) (kHz) |
| UVLO Thresholds On/Off (V) |
| Duty Cycle (Max) (%) |
| Gate Drive (Typ) (A) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Pin/Package |
| LM5039 | LM5035B | LM5035C | LM5036 | UCC28250 | UCC28251 |
| Full-Bridge Half-Bridge Push-Pull | Half-Bridge | Half-Bridge Push-Pull | Full-Bridge Half-Bridge Push-Pull | Forward Full-Bridge Half-Bridge Push-Pull | Forward Full-Bridge Half-Bridge Push-Pull |
| Voltage | Feedforward Voltage | Feedforward Voltage | Feedforward Voltage | Current Voltage | Current Feedforward Voltage |
| 13 | 13 | 13 | 18 | 4.3 | 4.3 |
| 105 | 105 | 105 | 100 | 20 | 20 |
| 2000 | 2000 | 2000 | 2000 | 1000 | 1000 |
| Programmable/1.25V | Programmable/1.25V | Programmable/1.25V | Programmable/1.25V | 4.3/4.1 | 4.3/4.1 |
| 50 | 50 | 50 | 50 | 100 | 100 |
| 2 | 2 | 2 | 2 | 0.2 | 0.2 |
| Multi-topology Synchronization Pin | Multi-topology Synchronization Pin | Synchronization Pin | Current Limiting Frequency Synchronization HV Start-up Input Line Monitor Integrated Switch Leading Edge Blanking Multi-topology Soft Start Synchronization Pin Thermal Shutdown Wide DC input | HV Start-up | Leading Edge Blanking Multi-topology Programmable Slope Compensation Soft Start Synchronization Pin |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| 20HTSSOP 24WQFN | 20HTSSOP 24WQFN | 20HTSSOP 24WQFN | 28WQFN | 20QFN 20TSSOP | 20QFN 20TSSOP |
