数据: TS5A12301E IEC Level 4 ESD-protected 0.75-Ω SPDT Analog Switch With 1.8-V Compatible Input Logic 数据表
TS5A12301E器件是双向,1通道,单刀双掷(SPDT)模拟开关,设计工作电压为2.25 V至5.5 V.该器件具有低导通电阻,具有出色的通道间导通电阻匹配和先开后合功能,可防止信号从一个路径传输到另一个路径时出现信号失真。
该器件具有出色的总谐波失真(THD)性能,功耗极低。这些功能使该设备适用于便携式音频应用。控制输入(IN)引脚可以连接到低压GPIO,允许它由1.8V信号控制。
TS5A12301E具有±15kV的气隙放电和±8kV COM端口与GND的接触放电ESD保护,使其符合IEC 4级ESD标准(IEC 61000-4-2)。
所有其他商标均为其各自所有者的财产
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Typ) (uA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| ON-state leakage current (Max) (µA) |
| Input/Output ON-state Capacitance (Typ) (pF) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| TS5A12301E |
| 2:1 SPDT |
| 1 |
| Single |
| N/A |
| N/A |
| 2.25 |
| 5.5 |
| 0.5 |
| 55 |
| Catalog |
| -40 to 85 |
| See datasheet (DSBGA) |
| DSBGA |
| 5.5 |
| 1.6 |
| 450 |
| 0.1 |
| 5 |
| Powered off protection Break-before-make |
| 0.1 |
| 0.2 |
| 112 |
| 28 |
| 1 |
| 3 |
| 0.65 |
| 1.05 |
