TPS795 超低噪声、高 PSRR、快速、射频、500mA 低压降线性稳压器
数据:
产品信息
描述 The TPS795 family of low-dropout (LDO), low-power linear voltage regulators features high power-supply rejection ratio (PSRR), ultralow noise, fast start-up, and excellent line and load transient responses in small outline, 6-pin SOT-223 and 3-mm × 3-mm WSON packages. Each device in the family is stable with a small 1-µF ceramic capacitor on the output. The family uses an advanced, proprietary BiCMOS fabrication process to yield extremely low dropout voltages (for example, 110 mV at 500 mA). Each device achieves fast start-up times (approximately 50 µs with a 0.001-µF bypass capacitor) while consuming very low quiescent current (265 µA, typical). Moreover, when the device is placed in standby mode, the supply current is reduced to less than 1 µA. The TPS79530 device exhibits approximately 33 µVRMS of output voltage noise at 3-V output with a 0.1-µF bypass capacitor. Applications with analog components that are noise-sensitive, such as portable RF electronics, benefit from the high-PSRR and low-noise features, as well as from the fast response time.特性500-mA Low-Dropout Regulator With EnableAvailable in Fixed and Adjustable (1.2-V to 5.5-V) VersionsHigh PSRR (50 dB at 10 kHz)Ultralow Noise (33 µVRMS, TPS79530)Fast Start-Up Time (50 µs)Stable With a 1-µF Ceramic CapacitorExcellent Load and Line Transient ResponseLow Dropout Voltage (110 mV at Full Load, TPS79530)6-Pin SOT-223 and 3-mm × 3-mm WSON PackagesAPPLICATIONSRF: VCOs, Receivers, ADCsAudioBluetooth®, Wireless LANCellular and Cordless TelephonesHandheld Organizers, PDAsAll other trademarks are the property of their respective owners.
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(1)
元器件购买 TPS795 相关库存
相关阅读
