DS90LV019-MIL 3.3V或5V LVDS驱动器/接收器
数据:
产品信息
描述The DS90LV019 is a Driver/Receiver designed specifically for the high speed low power point-to-point interconnect applications. The device operates from a single 3.3V or 5.0V power supply and includes one differential line driver and one receiver. The DS90LV019 features an independent driver and receiver with TTL/CMOS compatibility (DIN and ROUT). The logic interface provides maximum flexibility as 4 separate lines are provided (DIN, DE, RE#, and ROUT). The device also features a flow-through pin out which allows easy PCB routing for short stubs between its pins and the connector. The driver has 3.5 mA output loop current. The driver translates between TTL levels (single-ended) to Low Voltage Differential Signaling levels. This allows for high speed operation, while consuming minimal power with reduced EMI. In addition, the differential signaling provides common-mode noise rejection. The receiver threshold is ±100 mV over a ±1V common-mode range and translates the low swing differential levels to standard (TTL/CMOS) levels.特性LVDS Signaling 3.3V or 5.0V operation Low power CMOS design Balanced Output Impedance Glitch free power up/down (Driver disabled) High Signaling Rate Capacity (above 100 Mbps) Ultra Low Power Dissipation ±1V Common-Mode Range ±100 mV Receiver Sensitivity Product offered in SOIC and TSSOP packages Flow-Through Pin Out Industrial Temperature Range Operation TRI-STATE® is a registered trademark of National Semiconductor Corporation.
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(1)
元器件购买 DS90LV019-MIL 相关库存
相关阅读
