LM51501-Q1器件是一款具有宽输入电压范围的自动升压控制器。该器件可用于汽车启动期间利用车辆电池或备用电池维持稳定的输出电压。
可以通过一个电阻器在220kHz至2.3MHz范围内对LM51501-Q1开关频率进行编程。快速开关频率(≥2.2MHz)可最大限度地降低调幅频带干扰
LM51501-Q1在输入或输出电压高于预设待机阈值时以低I Q 待机模式运行,并且在输出电压降至预设唤醒阈值以下时自动唤醒。
该器件可进入或退出低I Q 待机模式,以在轻负载下延长电池寿命。单个电阻器对目标输出稳定电压以及配置进行编程。其他特性包括低关断电流,升压状态指示器,可调逐周期电流限制和热关断。当器件未进行升压运行时,状态指示器可用于控制电路以旁路掉极管,以降低功率耗散。在紧急呼叫模式下,它可用于控制断开开关,保护备用电池。
<小>所有商标是其相应所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Switch Current Limit (Typ) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Iout (Max) (A) |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM51501-Q1 | LM25122-Q1 | LM3481-Q1 | LM5122-Q1 | LM5150-Q1 | TPS40210-Q1 | TPS40211-Q1 |
| 1.5 | 3 | 2.97 | 3 | 1.5 | 4.5 | 4.5 |
| 42 | 42 | 48 | 65 | 42 | 52 | 52 |
| 6.0 | 3 | 1.275 | 3 | 6.8 | 6.4 | 6.4 |
| 11.5 | 50 | 500 | 100 | 10.5 | 300 | 60 |
| 15 | 20 | 10 | 20 | 15 | 6 | 6 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 220 | 50 | 100 | 50 | 220 | 35 | 35 |
| 2300 | 600 | 1000 | 1000 | 2300 | 1000 | 1000 |
| 0.015 | 4 | 3.7 | 4 | 0.015 | 0.53 | 0.53 |
| Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency | Enable Frequency Synchronization Phase Interleaving Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Pre-Bias Start-Up UVLO Adjustable | Enable Frequency Synchronization Phase Interleaving Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency | Enable Frequency Synchronization | Enable Frequency Synchronization |
| 87 | 100 | 85 | 100 | 87 | 95 | 95 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 150 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| WQFN | HTSSOP | VSSOP | HTSSOP | WQFN | MSOP-PowerPAD | MSOP-PowerPAD |
