LM46001调压器是一款易于使用的同步降压直流/直流转换器,能够驱动高达1A的负载电流,输入电压范围为3.5本文件采用峰值电流模式控制来实现简单控制环路补偿和逐周期电流限制。可选功能包括可编程开关频率,同步,电源正常标志,精确使能,内部软启动,可扩展软启动和跟踪,可为各种应用提供灵活且易于使用的平台。轻负载下的DCMmode和自动降频模式可提升轻负载效率。此系列只需要很少的外部组件,而且引脚排列可实现简单且优化的PCB布局。保护功能包括热关断, V CC 欠压锁定,逐周期电流限制和输出短路保护.LM46001器件采用16引线HTSSOP封装(PWP,6.6mm x 5.1mm x 1.2mm),线间距为0.65毫米。该器件与LM46000,LM46002,LM43603,LM43602,LM43601和LM43600引脚对引脚兼容。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM46001 | LM46002 | LM76002 | LMR36015 |
| 3.5 | 3.5 | 3.5 | 4.2 |
| 60 | 60 | 60 | 60 |
| 1 | 1 | 1 | 1 |
| 28 | 28 | 57 | 57 |
| 1 | 2 | 2.5 | 1.5 |
| 1 | 1 | 1 | 1 |
| 200 | 200 | 300 | 400 |
| 2200 | 2200 | 2200 | 1000 |
| 0.024 | 0.027 | 0.015 | 0.023 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable Forced Pulse Width Modulation (FPWM) Mode Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Wettable Flanks Package | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Wettable Flanks Package |
| Current Mode | Current Mode | Current Mode | Current Mode |
| 99 | 99 | 98 | |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 150 |
| Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | WQFN | VQFN-HR |
