数据: SN74CBTU4411 11 位 4 选 1 多路复用器/多路信号分离器 具有电荷泵和预充电输出的 1.8V DDR-II 开关 数据表 (Rev. B)
SN74CBTU4411器件是一种具备低导通状态电阻(r on )的高带宽SSTL_18兼容型FET多路复用户/多路信号分离器。此器件借助内部电荷泵提高通道晶体管的栅极电压,提供平缓的低r on 。平缓的低r on 可实现最短传播延迟,并且支持数据输入/输出(I /O)端口的轨道轨道号传输。此外,该器件还具备极低的数据I /O电容,能够尽可能减少数据总线上的容性负载以及信号失真现象。通道间相互匹配的r on 和I /O电容会形成超低差分以及上升沿或下降沿偏斜。得益于此,该器件可在DDR-II应用中表现出最佳性能。
所有商标均为各自所有者的财产。
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Typ) (uA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| Input/Output ON-state Capacitance (Typ) (pF) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| SN74CBTU4411 |
| 4:1 |
| 11 |
| Single |
| N/A |
| N/A |
| 1.7 |
| 1.9 |
| 10 |
| 400 |
| Catalog |
| 0 to 85 |
| 72NFBGA: 49 mm2: 7 x 7(NFBGA) |
| NFBGA |
| 1.9 |
| 17 |
| 100 |
| 2 |
| 20 |
| Pre-charged signal path Internal pull-down resistors |
| 10 |
| 4.6 |
| 2.5 |
| 0.75 |
| 2.5 |
| 0.66 |
| 1.1 |
