TS5A3359器件是双向,单通道,单刀三掷(SP3T)模拟开关,设计工作电压为1.65 V至5.5 V该器件提供信号切换解决方案,同时保持出色的信号完整性,使TS5A3359适用于各种市场的广泛应用,包括个人电子设备,测试和测量设备以及便携式仪器。该器件通过其低导通电阻,出色的导通电阻匹配和总谐波失真(THD)性能来保持信号完整性。为防止信号从一个通道传输到另一个通道期间的信号失真,TS5A3359器件还具有指定的先开后合功能。当V CC = 0时,器件功耗非常低,并提供隔离。
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Typ) (uA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| ON-state leakage current (Max) (µA) |
| Input/Output ON-state Capacitance (Typ) (pF) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| TS5A3359 |
| 3:1 |
| 1 |
| Single |
| N/A |
| N/A |
| 1.65 |
| 5.5 |
| 0.7 |
| 75 |
| Catalog |
| -40 to 85 |
| See datasheet (DSBGA) 8VSSOP: 6 mm2: 3.1 x 2(VSSOP) |
| DSBGA VSSOP |
| 5.5 |
| 3.5 |
| 200 |
| 0.01 |
| 1 |
| Powered off protection Break-before-make |
| 0.25 |
| 0.22 |
| 78 |
| 18 |
| 1 |
| 2 |
| 0.8 |
| 1.5 |
