要想stm应用u8g2绘制界面需要对u8g2原函数
u8g2_Setup_ssd1306_i2c_128x128_f(u8g2_t *u8g2, const u8g2_cb_t *rotation, u8x8_msg_cb byte_cb, u8x8_msg_cb gpio_and_delay_cb)里面后两个参数实现函数。
因为使用的软件实现i2c,所以u8x8_msg_cb byte_cb这个参数直接使用自带的u8x8_byte_sw_i2c即可,我们只要实现u8x8_msg_cb gpio_and_delay_cb这个参数写一个函数:
uint8_t u8x8_gpio_and_delay(u8x8_t *u8x8, uint8_t msg, uint8_t arg_int, void *arg_ptr)
switch (msg)
case U8X8_MSG_DELAY_100NANO: // delay arg_int * 100 nano seconds
__NOP();
break;
case U8X8_MSG_DELAY_10MICRO: // delay arg_int * 10 micro seconds
for (uint16_t n = 0; n < 320; n++)
__NOP();
break;
case U8X8_MSG_DELAY_MILLI: // delay arg_int * 1 milli second
HAL_Delay(1);
break;
case U8X8_MSG_DELAY_I2C: // arg_int is the I2C speed in 100KHz, e.g. 4 = 400 KHz
Tims_delay_us(5);
break; // arg_int=1: delay by 5us, arg_int = 4: delay by 1.25us
case U8X8_MSG_GPIO_I2C_CLOCK: // arg_int=0: Output low at I2C clock pin
if(arg_int==1)
HAL_GPIO_WritePin(OLEDSCK_GPIO_Port,OLEDSCK_Pin,GPIO_PIN_SET);
else
if(arg_int==0)
{HAL_GPIO_WritePin(OLEDSCK_GPIO_Port,OLEDSCK_Pin,GPIO_PIN_RESET);}
break; // arg_int=1: Input dir with pullup high for I2C clock pin
case U8X8_MSG_GPIO_I2C_DATA: // arg_int=0: Output low at I2C data pin
if(arg_int==1)
HAL_GPIO_WritePin(OLEDSDA_GPIO_Port,OLEDSDA_Pin,GPIO_PIN_SET);
else
if(arg_int==0)
{HAL_GPIO_WritePin(OLEDSDA_GPIO_Port,OLEDSDA_Pin,GPIO_PIN_RESET);}
break; // arg_int=1: Input dir with pullup high for I2C data pin
case U8X8_MSG_GPIO_MENU_SELECT:
u8x8_SetGPIOResult(u8x8, /* get menu select pin state */ 0);
break;
case U8X8_MSG_GPIO_MENU_NEXT:
u8x8_SetGPIOResult(u8x8, /* get menu next pin state */ 0);
break;
case U8X8_MSG_GPIO_MENU_PREV:
u8x8_SetGPIOResult(u8x8, /* get menu prev pin state */ 0);
break;
case U8X8_MSG_GPIO_MENU_HOME:
u8x8_SetGPIOResult(u8x8, /* get menu home pin state */ 0);
break;
default:
u8x8_SetGPIOResult(u8x8, 1); // default return value
break;
return 1;
划线的地方是需要根据我们自己对stm32 io口配置和us、ms延时函数自己需要修改的。实现后写入函数参数:
u8g2_Setup_ssd1306_i2c_128x128_f(&u8g2, U8G2_R0, u8x8_byte_sw_i2c, u8x8_gpio_and_delay);
接下来就可以测试下:
#include"u8g2.h" #include"u8x8.h" #include"TimeDelay.h" #include"icon.h" #include "ui.h" {……..} u8g2_Setup_ssd1306_i2c_128x128_f(&u8g2, U8G2_R0, u8x8_byte_sw_i2c, u8x8_gpio_and_delay); // 初始化u8g2 结构体 u8g2_InitDisplay(&u8g2); //对缓存进行初始化 // 初始化u8x8_gpio_and_delay函数 u8g2_SetPowerSave(&u8g2, 0); //wake up 屏幕 // 初始化u8x8_byte_hw_i2c函数 u8g2_ClearBuffer(&u8g2); //清除缓存区 HAL_Delay(1); /* USER CODE END 2 */ /* Infinite loop */ /* USER CODE BEGIN WHILE */ while (1) { u8g2_DrawLine(&u8g2, -16,-16, 127, 127); u8g2_DrawLine(&u8g2, 0,50, 100, 50); u8g2_DrawLine(&u8g2, 0,0, 0,100); u8g2_SetFont(&u8g2,u8g2_font_helvR08_tr); u8g2_DrawButtonUTF8(&u8g2,4, 20, U8G2_BTN_BW2, 0, 2, 2, "Btn" ); u8g2_SetFont(&u8g2,u8g2_font_ncenB14_tr); u8g2_DrawStr(&u8g2,0,45,"Hello World!"); u8g2_SendBuffer(&u8g2); u8g2_ClearBuffer(&u8g2); }
举报投诉
STM32
2313文章
11195浏览量
374718 -
u8g2
18浏览量
2411
热点推荐
ATmega8U2/16U2/32U2微控制器:高性能与低功耗的完美结合
ATmega8U2/16U2/32U2微控制器:高性能与低功耗的完美结合 在电子设计领域,一款优秀的微控制器往往能为项目带来事半功倍的效果。ATmega
【RA-Eco-RA4M2开发板评测】+ 开发环境搭建及外设初体验
_t msg, uint8_t arg_int, void *arg_ptr);
void u8g2Init(u8g2_t *u8g2)
//初始化
发表于 03-30 23:15
深入解析BGSX24M2U16:适用于LTE与5G的DP4T天线交叉开关
深入解析BGSX24M2U16:适用于LTE与5G的DP4T天线交叉开关 在当今的通信领域,LTE和5G技术的飞速发展对射频前端设备提出了更高的要求。BGSX24M2U16作为
【新品】8盘位PCIe5.0 U.2/U.3 NVMe 转 双5.25光驱位硬盘抽取盒
和媒体工作站设计。通过4个MCIO8i(SFF-TA-1016)接口,最多可支持8块5-15mm厚的U.2/U.3NVMeSSD,每块SSD均可提供PCIeGen5x
兼容遇难题?原生U.2即正解!艾西达克单盘位U.2硬盘盒测评
/U.3硬盘抽取盒MB741V4P-B。该产品仅占用一个3.5英寸光驱位,即可实现对U.2/U.3硬盘的稳定识别与高速读取。其机身采用多面镂空结构,构建高效散热风
STM32 Nucleo-U385RG-Q开发板技术解析与应用指南
STMicroelectronics NUCLEO-U385RG-Q开发板(带STM32U3 MCU)是一款多功能、全面的评估平台,设计用于让开发人员使用STM32U385RGT6Q微
RA-Eco-RA6M4部分功能测评3
C的SCL/SDA切换)和延时功能(满足通信时序要求);
通信接口回调函数:负责实现I2C/SPI等物理层通信,完成数据向OLED控制器的传输。
这两类函数需遵循
发表于 09-05 20:47
【RA-Eco-RA6M4开发板评测】2、I2C外设驱动OLED屏幕和移植u8g2
ssd1306(兼容ssd1315)设备的初始化函数,这里使用该函数是可以点亮屏幕的,使用其他的则有问题。
OLED的屏幕显示效果如下。
总结
移植现有的u8g2图形库,完成需要的回调函数
发表于 07-23 13:51
基于极海APM32F411 MCU移植U8g2驱动OLED指南
基于Arm Cortex-M4F内核,工作主频120MHz,具有高速运算能力、多种工作模式、以及丰富的高精度外设和通讯接口;内置CRC32运算单元,可为用户提供高集成度、高可靠性的SoC方案;作为APM32F4系列MCU的超值型拓展产品,能很好的满足用户对功耗、性能、性价比方面的产品均衡需求,可适用于电力,仪器仪表,工控,家电,物联网,新能源,智慧楼宇等广泛的应用领域。
零知开源——STM32F4结合BMP581气压传感器实现ST7789中文显示教程
传感器数据采集。通过U8g2库实现高质量中文渲染,混合Adafruit_GFX进行高效数据显示,实时展示温度、压力和高度数据。教程详细介绍了硬件连接方案(I2C/SPI接口)、软件架构设计(包含库依赖关系和数据读取机制)以及中文文本渲染方法。
;gt;使用U8g2库实现高质量中文渲染
>混合使用Adafruit_GFX和U8g2实现高效显示
>实时显示温度、压力和高度数据
>针对STM32F4系列优化
发表于 07-08 18:55
请问STM32G431内部运放1和2输出连接的ADC为什么不是OPAMP?
和ADC2 3通道,而W相输出是ADC1 12通道和OPAMP3通道呢?不应该U和V相也有OPAMP1和OPAMP2通道吗?三个运放应该是一模一
发表于 06-10 07:39
STM32U5+8bit_8080 LCD 怎么配置touchgfx?
我参与的项目使用STM32U575做为主空,使用fmc来驱动8080接口的8bitLCD,配置touchgfx时不能配置为8bit,其他选型例如DMA2D也使用不了,我该怎么做?
发表于 06-09 06:23
零知开源——STM32F1驱动MAX31865读取三线PT100温度传感器
逻辑
setup()函数,
初始化串口、OLED和MAX31865,设置三线制模式:void setup() {
Serial.begin(115200);
u8g2.begin(); // 启动OLED
发表于 05-23 18:27
求一份CS32G020K8U6的keil的chipsea.CS32G02x_DFP.pack安装包,谢谢
用CS32G020K8U6开发充电宝方案,工作交接导致keil相关的pack缺失,麻烦哪位好心人给我发一份到邮箱694306192@qq.com,谢谢啦
发表于 05-21 11:30
关于stm32,u8g2菜单之间切换(三)写u8g2的一些必要函数
