在快速迭代的无线通信技术浪潮中,一款集高性能、高集成度与环保理念于一身的射频前端模组——KCT8243HE,正以其无与伦比的优势,引领着Wi-Fi 6时代的发展潮流。专为2.4-2.5GHz频段打造,KCT8243HE不仅满足了802.11b/g/n/ac/ax WLAN系统的所有关键射频需求,更以卓越的设计理念和精湛的工艺技术,重新定义了射频前端器件的卓越标准。
In the rapidly iterating wave of wireless communication technology, a RF front-end module with high performance, high integration and environmental protection concept - KCT8243HE is leading the development trend of the Wi-Fi 6 era with its unparalleled advantages. Built specifically for the 2.4-2.5GHz band, the KCT8243HE not only meets all the critical RF requirements for 802.11b/g/n/ac/ax WLAN systems, but also redefines the standard of excellence for RF front-end devices with superior design concepts and exquisite process technology.
KCT8243HE集成了高效率、高线性的功率放大器(PA)、包含旁路滤波器(BP)的低噪声放大器(LNA)、LO抑制和谐波滤波器,以及直流电压功率检测功能,为客户提供了从信号发射到接收的一站式射频解决方案。这一高度集成的设计,不仅显著降低了射频前端的设计复杂度,更提升了系统的整体性能和稳定性。
The KCT8243HE integrates a high-efficiency, high-linearity power amplifier (PA), a low-noise amplifier (LNA) with a bypass filter (BP), LO suppression and harmonic filters, and DC voltage power detection to provide customers with a one-stop RF solution from signal transmission to reception. This highly integrated design not only significantly reduces the design complexity of the RF front-end, but also improves the overall performance and stability of the system.
模组提供了完整的输入输出端匹配方案,确保射频信号在传输过程中的损耗最小。同时,极简的外部电路匹配方案,使得客户只需连接少量外部元件,即可轻松实现射频信号的传输和接收。这一设计大大简化了电路结构,降低了开发难度和成本。
The module provides a complete input and output matching scheme to ensure the minimum loss of RF signal during transmission. At the same time, the minimalist external circuit matching scheme allows customers to easily transmit and receive RF signals by connecting only a small number of external components. This design greatly simplifies the circuit structure and reduces the difficulty and cost of development.
卓越性能,稳定可靠
1. 高增益、低噪声
KCT8243HE的功率放大器在5V供电下,传输增益可达33.5dB,确保信号在传输过程中的强度。同时,低噪声放大器具有1.5dB的超低噪声系数,即使在接收微弱信号时,也能保持高的信噪比。这一设计使得模组在复杂环境中也能稳定工作,提供优质的无线通信体验。
2. 强大输出功率
模组在HE40/MCS11调制方式下,输出功率可达+21.5dBm至+22.5dBm;在VHT40/MCS9调制方式下,输出功率可达+24.5dBm;在HT20/MCS7调制方式下,输出功率更是高达+25.5dBm。这些优异的输出功率表现,使得KCT8243HE能够满足各种高性能Wi-Fi应用的需求。
3. 内置功率检测
模组内置的直流电压功率检测功能,能够实时监测功率放大器的输出功率,确保系统的稳定运行。这一功能对于优化系统性能、避免过功率损坏具有重要意义。
紧凑封装,环保节能
1. 小巧封装,节省空间
KCT8243HE采用QFN-24L封装,尺寸仅为3mm5mm0.75mm,小巧精致,节省电路板空间。这一紧凑的设计使得模组能够轻松适应各种小型化的设备,满足现代电子产品的轻薄化需求。
2. 环保认证,安全可靠
模组通过了ROHS和REACH环保认证,符合欧盟对电子电气产品中有害物质使用的限制要求。这一认证不仅体现了我们对环保的重视,更为客户提供了更加安全、可靠的产品选择。
四、全面防护,提升耐用性
1. ESD保护电路
KCT8243HE的所有引脚都配备了ESD保护电路,以确保模组在受到静电放电冲击时能够正常工作。这一设计大大提高了模组的抗干扰能力和使用寿命。
2。 高温稳定性
模组符合JEDEC J-STD-020标准的MSL3等级要求,能够在260℃的高温下正常工作。这一优异的热性能使得模组能够适用于各种高温环境下的应用,确保系统的稳定运行。
功率放大器
104文章
4152浏览量
139005 -
模组
6文章
1721浏览量
32023 -
射频前端
5文章
277浏览量
25118
860 至 930 MHz 射频前端模块 skyworksinc
射频前端“硬骨头”之战:昂瑞微啃下中高端模组市场
昂瑞微:射频前端的“破局者”,迈向中高端模组新纪元
长电科技射频模组封装技术助力提升用户体验
国产射频前端行业,第二次冲锋
射频前端的反内卷之路
Wi-Fi7产品需求强劲,高通、Synaptics和康希通信放何大招?
902 – 928 MHz 高功率射频前端模块 skyworksinc
860 – 930 MHz 高功率射频前端模块 skyworksinc
860-930 MHz 射频前端模块 skyworksinc
902 至 928 MHz 高功率射频前端模块 skyworksinc
1787 至 1930 MHz 高功率射频前端模块 skyworksinc
希恩凯电子携液晶显示模组亮相2025泉州通信展
一文了解5G射频前端模组中的滤波器
康希通信美林美深射频前端模组KCT8243HE型号
