SN65MLVD20xx器件是多点低压差分(M-LVDS)线路驱动器和接收器,经过优化,可在高达100 Mbps的信号速率下工作。所有器件均符合多点低压差分信号(M-LVDS)标准TIA /EIA-899。
SN65MLVD20xx器件比其前代器件具有增强功能。改进的功能包括驱动器输出上的受控压摆率,有助于最大限度地减少未端接短截线的反射,从而实现更好的信号完整性。此外,总线引脚上的8 kV ESD保护可提供更高的稳健性。保持相同的占位面积定义,以便轻松替换系统性能升级。
这些器件的特点是在-40°C至85°C的温度范围内工作。
| Device Type |
| Protocols |
| No. of Tx |
| No. of Rx |
| Input Signal |
| Output Signal |
| Signaling Rate (Mbps) |
| ESD HBM (kV) |
| Function |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| SN65MLVD205A | SN65MLVD200A | SN65MLVD201 | SN65MLVD202A | SN65MLVD203 | SN65MLVD204B | SN65MLVD206B | SN65MLVD207 |
| Transceiver | Transceiver | Transceiver | Transceiver | Transceiver | Transceiver | Transceiver | Transceiver |
| M-LVDS | M-LVDS | M-LVDS | M-LVDS | M-LVDS | M-LVDS | M-LVDS | M-LVDS |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS | LVTTL M-LVDS |
| 100 | 100 | 200 | 100 | 200 | 100 | 200 | 200 |
| 8 | 8 | 8 | 8 | 8 | 8 | 8 | 8 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| SOIC | SOIC | SOIC | SOIC | SOIC | SOIC | SOIC | SOIC |
| 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) |
| 14SOIC | 8SOIC | 8SOIC | 14SOIC | 14SOIC | 8SOIC | 8SOIC | 14SOIC |
