DRV8843为打印机,扫描仪和其他自动设备应用提供集成的双路H桥电机驱动器解决方案。该器件可用于驱动一个或两个刷式直流电机,一个双极性步进电机或其它负载。通过一个简单的PWM接口即可轻松与控制器电路相连。
输出驱动器块包括配置为H桥的N沟道功率MOSFET.DRV8843可为每个H桥提供高达2.5A的峰值电流或1.75A的均方根(RMS)输出电流(在24V与
TA = 25°C时提供适当散热功能)。
低功耗睡眠模式可将部分内部电路关断,以实现极低的静态电流和功耗。可使用一个专用的nSLEEP引脚来设定这个睡眠模式。
该器件内置以下保护功能:过热,过流和欠压。故障条件通过nFAULT引脚指示。
所有商标是他们各自所有者的财产。
| Vs (Min) (V) |
| Vs (Max) (V) |
| Number of Full Bridges |
| RDS(ON) (HS + LS) (mOhms) |
| RMS Output Current (A) |
| Peak Output Current (A) |
| Micro-Stepping Levels |
| Control I/F |
| Features |
| Pin/Package |
| Rating |
| Operating Temperature Range (C) |
| DRV8843 | DRV8813 | DRV8841 | DRV8881 |
| 8.2 | 8.2 | 8.2 | 6.5 |
| 45 | 45 | 45 | 45 |
| 2 | 2 | 2 | 2 |
| 400 | 400 | 400 | 630 |
| 1.75 | 1.75 | 1.75 | 1.41 |
| 2.5 | 2.5 | 2.5 | 2.5 |
| 4 | 4 | 4 | |
| PWM | PH/EN | PWM | PWM PH/EN |
| High Microstepping with External Reference Current Regulation | High Microstepping with External Reference Current Regulation | High Microstepping with External Reference Current Regulation | AutoTune High Microstepping with External Reference Current Regulation |
| 28HTSSOP | 28HTSSOP | 28HTSSOP | 28HTSSOP 28WQFN |
| Catalog | Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 |
