LM5150-Q1器件是宽输入范围自动升压控制器。该器件适合用作预升压转换器,在汽车启动期间维持汽车电池的输出电压,或在缺少汽车电池期间维持备用电池的输出电压。
可以通过一个电阻器在220kHz与2.3MHz之间对LM5150-Q1开关频率进行编程。快速开关(≥2.2) ())最优大度地降低调幅频带干扰,并支持实现小解决方案尺寸和快速瞬态响应。
LM5150-Q1在输入或输出电压高于预设待机阈值时以低I < sub> Q 待机模式运行,并且在输出电压降至预设唤醒阈值以下时自动唤醒。
处于或未处于低I Q 待机模式的器件瞬态,可在轻负载下延长电池寿命。单个电阻器对目标输出稳定电压以及配置进行编程。其他特性包括低关断电流,升压状态指示器,可调逐周期电流限制和热关断。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Switch Current Limit (Typ) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Iout (Max) (A) |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM5150-Q1 | LM25122-Q1 | LM3481-Q1 | LM5022-Q1 | LM5122-Q1 | LM51501-Q1 | TPS40210-Q1 | TPS40211-Q1 |
| 1.5 | 3 | 2.97 | 3 | 3 | 1.5 | 4.5 | 4.5 |
| 42 | 42 | 48 | 60 | 65 | 42 | 52 | 52 |
| 6.8 | 3 | 1.275 | 1.25 | 3 | 6.0 | 6.4 | 6.4 |
| 10.5 | 50 | 500 | 300 | 100 | 11.5 | 300 | 60 |
| 15 | 20 | 10 | 10 | 20 | 15 | 6 | 6 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 220 | 50 | 100 | 170 | 50 | 220 | 35 | 35 |
| 2300 | 600 | 1000 | 2200 | 1000 | 2300 | 1000 | 1000 |
| 0.015 | 4 | 3.7 | 3.5 | 4 | 0.015 | 0.53 | 0.53 |
| Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency | Enable Frequency Synchronization Phase Interleaving Synchronous Rectification | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency Pre-Bias Start-Up UVLO Adjustable | Enable Frequency Synchronization UVLO Adjustable | Enable Frequency Synchronization Phase Interleaving Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Frequency Synchronization Light Load Efficiency | Enable Frequency Synchronization | Enable Frequency Synchronization |
| 87 | 100 | 85 | 90 | 100 | 87 | 95 | 95 |
| -40 to 150 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| WQFN | HTSSOP | VSSOP | VSSOP | HTSSOP | WQFN | MSOP-PowerPAD | MSOP-PowerPAD |
