这个器件为电池供电的/永远在线的汽车应用(如遥控免钥匙进入(RKE)或被动进入被动启动(PEPS)钥匙和基站)提供了低功耗优势。借助2V-6V的输入电压范围,这些器件支持由锂二氧化锰(Li-MnO2)纽扣电池,锂离子电池,两节(2S)和三节(3S)碱性电池,3.3V和5V输入电压轨进行供电的应用.TPS6224x-Q1在高负载电流情况下以2.25MHz的固定开关频率运行,在轻负载电流情况下会进入省电模式,以便在整个负载电流范围内保持高效率和低功耗。此省电模式针对低输出电压纹波进行了优化。在关断模式下,电流消耗减少至1μA以下.TPS6224x-Q1允许使用小型电感器和电容器来实现较小的解决方案尺寸,并采用5引脚TSOT23封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62244-Q1 | TPS62231-Q1 | TPS622314-Q1 | TPS62242-Q1 | TPS62243-Q1 | TPS62260-Q1 | TPS62290-Q1 |
| 2 | 2.05 | 2.05 | 2 | 2 | 2 | 2.3 |
| 6 | 6 | 6 | 6 | 6 | 6 | 6 |
| 1.25 | 1.8 | 1.5 | 1.2 | 1.8 | 0.6 | 0.6 |
| 1.25 | 1.8 | 1.5 | 1.2 | 1.8 | 6 | 6 |
| 0.3 | 0.5 | 0.5 | 0.3 | 0.3 | 0.6 | 1 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2250 | 3000 | 3000 | 2250 | 2250 | 2250 | 2250 |
| 2250 | 3000 | 3800 | 2250 | 2250 | 2250 | 2250 |
| 0.015 | 0.022 | 0.022 | 0.015 | 0.015 | 0.015 | 0.015 |
| Enable Light Load Efficiency Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification |
| Voltage Mode | Constant on-time (COT) DCS-Control | Voltage Mode DCS-Control | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 105 | -40 to 105 | -40 to 115 | -40 to 125 | -40 to 105 -40 to 85 | -40 to 105 -40 to 85 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| SOT-23-THIN | SON | SON | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN WSON | WSON |
