数据: LMR23625-Q1 SIMPLE SWITCHER® 36V、2.5A 同步降压转换器 数据表 (Rev. B)
LMR23625-Q1 SIMPLE SWITCHER ®是一款简便易用的36V,2.5A同步降压稳压器。器件具有4V至36V的宽输入范围,适用于从工业到汽车各类应用中非稳压电源的电压调节。采用峰值电流模式控制来实现简单控制环路补偿和逐周期电流限制。其静态电流低至少75μA,因此适用于电池供电类系统。这部还能够最大限度地减少外部元件数。该器件还具有固定频率强制脉冲宽度调制模式(FPWM)模式选项,可在轻载时实现较小的输出电压纹波。该器件的扩展系列产品能够以引脚到引脚兼容的封装提供1A(LMR23610-Q1),1.5A(LMR23615- Q1)和3A(LMR23630-Q1)负载电流选项,从而可以实现简单且最佳的PCB布局。利用精密使能端输入可以简化稳压器控制和系统电源定序。保护特性包括逐周电流限制,间断模式短路保护和过多功率耗散而引起的热关断。
<小>所有商标是其相应所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LMR23625-Q1 | LM22672-Q1 | LM43601-Q1 | LM43602-Q1 | LM43603-Q1 | LM5576-Q1 | LMR14020-Q1 | LMR14030-Q1 | LMR16006Y-Q1 | LMR23610-Q1 | LMR23615-Q1 | LMR23630-Q1 |
| 4 | 4.5 | 3.5 | 3.5 | 3.5 | 6 | 4 | 4 | 4 | 4 | 4 | 4 |
| 36 | 42 | 36 | 36 | 36 | 75 | 40 | 40 | 40 | 36 | 36 | 36 |
| 1 | 1.285 | 1 | 1 | 1 | 1.23 | 1 | 1 | 0.8 | 1 | 1 | 1 |
| 34 | 37 | 28 | 28 | 28 | 70 | 30 | 30 | 36 | 34 | 28 | 34 |
| 2.5 | 1 | 1 | 2 | 3 | 3 | 2 | 3.5 | 0.6 | 1 | 1.5 | 3 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 200 | 200 | 200 | 200 | 200 | 50 | 200 | 200 | 700 | 200 | 200 | 200 |
| 2200 | 1000 | 2200 | 2200 | 2200 | 500 | 2500 | 2500 | 2100 | 2200 | 2200 | 2200 |
| 0.075 | 3.4 | 0.033 | 0.027 | 0.027 | 1 | 0.04 | 0.04 | 0.028 | 0.075 | 0.075 | 0.075 |
| Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification | Enable | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Spread Spectrum Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Spread Spectrum Tracking UVLO Adjustable | Enable Light Load Efficiency Pre-Bias Start-Up UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification | Enable Frequency Synchronization Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Synchronous Rectification |
| Current Mode | Voltage Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 99 | 90 | 99 | 99 | 99 | 95 | 98 | 98 | 97 | 99 | 97 | 99 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| SO PowerPAD SON | SO PowerPAD | HTSSOP | HTSSOP | HTSSOP | HTSSOP | SO PowerPAD WSON | SO PowerPAD WSON | SOT-23-THIN | SO PowerPAD | SON | SO PowerPAD SON |
