数据: 采用 SOT-23 封装的 TPS565208 4.5V 至 17V 输入、5A 同步降压稳压器 数据表 (Rev. A)
TPS565208是一款采用SOT-23封装的简单易用型5A同步降压转换器。
该器件经过优化,最大限度地减少了运行所需的外部组件并且可以实现低待机电流。
此开关模式电源(SMPS)器件采用D-CAP2™模式控制,此控制方式无需外部补偿组件即可实现快速瞬态响应.D-CAP2™还支持使用低等效串联电阻(ESR)专用聚合物电容器和陶瓷电容器。
TPS565208采用6引脚1.6mm×2.9mm SOT(DDC) )封装,可在-40°C至125°C的结温范围下运行。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS565208 | TPS561208 | TPS562201 | TPS562208 | TPS563201 | TPS563208 | TPS563249 | TPS564201 | TPS564208 | TPS565201 |
| 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 | 4.5 |
| 17 | 17 | 17 | 17 | 17 | 17 | 17 | 17 | 17 | 17 |
| 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.6 | 0.76 | 0.76 | 0.76 |
| 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 | 7 |
| 5 | 1 | 2 | 2 | 3 | 3 | 3 | 4 | 4 | 5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 500 | 580 | 580 | 580 | 580 | 580 | 1400 | 500 | 500 | 400 |
| 500 | 580 | 580 | 580 | 580 | 580 | 1400 | 600 | 600 | 600 |
| 0.6 | 0.4 | 0.4 | 0.4 | 0.4 | 0.4 | 0.26 | 0.4 | 0.4 | 0.4 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Over Current Protection Pre-Bias Start-Up Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Synchronous Rectification | Enable Light Load Efficiency Synchronous Rectification |
| D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP2 | D-CAP3 | D-CAP2 | D-CAP2 | D-CAP2 |
| 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | 80 | |
| -40 to 125 | -40 to 85 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN |
