数据: 带有 Eco-mode™ 控制的 1.5A 60V 降压 SWIFT™ DC/DC 转换器 数据表 (Rev. C)
TPS57160-Q1器件是一款60V 1.5A降压型稳压器,此稳压器具有一个集成型高侧MOSFET。电流模式控制提供简单的外部补偿和灵活的组件选择。低纹波脉冲跳跃模式将无负载输出电源电流减小至116μA。通过使用使能引脚,关断电源电流被减少至1.5μA。
< p>欠压闭锁在内部设定为2.5V,但可采用使能引脚将它提高。输出电压启动斜坡受控于缓慢启动引脚,该引脚还可被配置用来控制电源排序或者跟踪。一个开漏电源良好信号表示输出处于其标称电压值的92%至109%之内。宽开关频率范围实现了对效率及外部组件尺寸的优化。频率折返和热关断功能可在过载情况下对部件提供保护。
TPS57160-Q1采用10引脚耐热增强型微型小外形尺寸(MSOP)PowerPAD(DGQ)或者10引脚小外形尺寸无引线(SON)(DRC)封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS57160-Q1 | LM46001-Q1 | LM46002-Q1 | LM5160-Q1 | LMR16020 | TPS54240-Q1 | TPS54260-Q1 | TPS57040-Q1 | TPS57060-Q1 | TPS57140-Q1 |
| 3.5 | 3.5 | 3.5 | 4.5 | 4.3 | 3.5 | 3.5 | 3.5 | 3.5 | 3.5 |
| 60 | 60 | 60 | 65 | 60 | 42 | 60 | 42 | 60 | 42 |
| 0.8 | 1 | 1 | 2 | 1 | 0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
| 58 | 28 | 28 | 60 | 50 | 39 | 58 | 39 | 58 | 39 |
| 1.5 | 1 | 2 | 1.5 | 2 | 2.5 | 2.5 | 0.5 | 0.5 | 1.5 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 100 | 200 | 200 | 50 | 200 | 100 | 100 | 100 | 100 | 100 |
| 2500 | 2200 | 2200 | 1000 | 2500 | 2500 | 2500 | 2500 | 2500 | 2500 |
| 0.116 | 0.024 | 0.027 | 2.3 | 0.04 | 0.138 | 0.138 | 0.116 | 0.116 | 0.116 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Enable Light Load Efficiency Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Pre-Bias Start-Up Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable | Enable Frequency Synchronization Light Load Efficiency Power Good Tracking UVLO Adjustable |
| Current Mode | Current Mode | Current Mode | Constant on-time (COT) | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode | Current Mode |
| 100 | 99 | 99 | 92 | 98 | 100 | 100 | 100 | 98 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Catalog | Automotive | Automotive | Automotive | Automotive | Automotive |
| MSOP-PowerPAD VSON | HTSSOP | HTSSOP | HTSSOP | SO PowerPAD | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON | MSOP-PowerPAD VSON |
