LM3151 /2/3SIMPLESWITCHER®控制器是一款简单易用,且可在典型应用中提供达12A输出电流的简易降压电源控制器。工作输入电压范围为6V-42V的LM3151 /2/3可输出固定的3.3V电压及250 kHz,500 kHz和750 kHz开关频率。同步架构提供了更高效的设计。具有已注册专利的仿纹波模式(ERM)控制技术的LM3151 /2/3控制器采用固定导通时间(COT)结构,可使用低等效串联电阻(ESR)输出电容器,从而降低了整体设计方案尺寸和输出电压纹波。固定导通时间(COT)调节结构具有特快的瞬态响应,且无需外置环路补偿,有助于减少外置元件数和降低设计复杂性。故障保护特性,比如热关断,欠电压锁定,过电压保护,短路保护,电流限制以及输出电压预偏压启动使一种可靠且稳定的解决方案得以实现。
LM3151 /2/3SIMPLESWCHCHER®方案使用最少外置元件数和美国国家半导体的WEBENCH®网上设计工具来完成整套易用设计.WEBENCH®为每步设计过程提供设计支持,包括使用新的MOSFET选择器进行外置元件计算,电气模拟,热模拟和建模板等。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Number of Phases |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| Control Mode |
| LM3151 | LM3150 | LM3152 | LM3153 |
| 6 | 6 | 6 | 8 |
| 42 | 42 | 33 | 18 |
| 3.3 | 0.6 | 3.3 | 3.3 |
| 3.3 | 40 | 3.3 | 3.3 |
| 12 | 12 | 12 | 12 |
| 1 | 1 | 1 | 1 |
| 1 | 1 | 1 | 1 |
| 250 | 200 | 500 | 750 |
| 250 | 1000 | 500 | 750 |
| 3.6 | 3.5 | 3.6 | 3.6 |
| Enable Synchronous Rectification Tracking | Adjustable Current Limit Enable Frequency Synchronization Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Enable Synchronous Rectification Tracking | Enable Synchronous Rectification Tracking |
| 90 | 96 | 81 | 72 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Catalog | Catalog | Catalog | Catalog |
| HTSSOP | HTSSOP | HTSSOP | HTSSOP |
| COT with emulated ripple | COT with emulated ripple | COT with emulated ripple | COT with emulated ripple |
