TLV3544-Q1系列高速电压反馈CMOS运算放大器专为视频应用和其他需要宽带宽的应用而设计。这些器件单位增益稳定,可以输出大电流。差分增益为0.02%,而差分相位为0.09°。静态电流仅为每通道4.9mA。
TLV3544-Q1四通道运算放大器针对低至2.5V(±1.25V)和高达5.5V(±2.75V)的单电源或双电源供电运行进行了优化。共模输入范围超出电源供电范围。电源轨的输出摆幅在100mV以内,从而支持宽动态范围。
< p>多通道版本具有完全独立的电路,可将串扰降到最低并彻底消除相互干扰。所有器件的额定扩展工作温度范围为-40°C至+ 125°C。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| TLV3544-Q1 |
| CMOS Voltage FB |
| 4 |
| 2.5 |
| 5.5 |
| 250 |
| 1 |
| 150 |
| 6.5 |
| 6.5 |
| 4.9 |
| 8 |
| In Out |
| N/A |
| Automotive |
| -40 to 125 |
| TSSOP |
| 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 80 |
| 50 |
| 4 |
| 250 |
| 100 |
| 75 |
| 83 |
| 1 |
