OPA837和OPA2837是单通道和双通道单位增益稳定电压反馈放大器,与其他精密运算放大器相比能够提供较高的MHz /mW带宽。这两款3.0mW器件每通道仅消耗600μA(通过单个5V电源),能够以1V /V的增益提供105MHz带宽。±130μV(最大值)的极低修整失调电压可提供典型值(±1σ)对于±0.4μV/°C的温漂。
OPAx837理论上非常适合单端逐次逼近型寄存器(SAR)模数转换器(ADC)驱动应用,能够针对3mW静态功率提供一种较低的输入点噪声级别(4.7nV /√ Hz )。极高的50MHz增益带宽积可针对高频率提供低输出阻抗,这是在SAR ADC驱动器应用中提供快速充电电流所必需的。该低通态输出阻抗还适用于采用精密ADC的基准缓冲器应用。单通道OPA837采用6引脚SOT-23封装(包括电源关断特性)和5引脚SC70封装,而双通道OPA2837则采用8引脚VSSOP封装。
OPAx837具有-40°C至+ 125°C的宽额定运行温度范围。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA837 | OPA2836 | OPA2837 | OPA835 | OPA836 | OPA838 |
| Voltage FB | Bipolar Voltage FB | Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB |
| 1 | 2 | 2 | 1 | 1 | 1 |
| 2.7 | 2.5 | 2.7 | 2.5 | 2.5 | 2.7 |
| 5.4 | 5.5 | 5.4 | 5.5 | 5.5 | 5.4 |
| 105 | 205 | 105 | 56 | 205 | 90 |
| 1 | 1 | 1 | 1 | 1 | 6 |
| 105 | 560 | 105 | 160 | 560 | 350 |
| 4.7 | 4.6 | 4.7 | 9.3 | 4.6 | 1.8 |
| 0.592 | 1 | 0.592 | 0.25 | 1 | 0.96 |
| 0.13 | 0.4 | 0.13 | 0.5 | 0.4 | 0.125 |
| In to V- Out | In to V- Out | In to V- | In to V- Out | In to V- Out | In to V- Out |
| Small Size Shutdown | Small Size Shutdown | Small Size Shutdown | Small Size Shutdown | Small Size Shutdown | |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| SC70 SOT-23 | QFN SOIC UQFN VSSOP | QFN VSSOP | QFN SOT-23 | QFN SOT-23 | SC70 SC70 SOT-23 |
| 5SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 10QFN: 4 mm2: 2 x 2(QFN) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 10UQFN: 4 mm2: 2 x 2(UQFN) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 10QFN: 4 mm2: 2 x 2(QFN) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SC70: 4 mm2: 2.1 x 2(SC70) 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 110 | 116 | 110 | 113 | 116 | 105 |
| 520000 | 1000000 | 520000 | 400000 | 1000000 | 4400000 |
| 0.4 | 1.1 | 0.4 | 2.25 | 1.1 | 0.4 |
| 50 | 120 | 50 | 30 | 120 | 300 |
| 50 | 50 | 50 | 40 | 50 | 20 |
| 120 | 85 | 120 | 70 | 85 | -110 |
| 145 | 79 | 145 | 73 | 79 | -120 |
| 0.1 | 1 | 0.1 | 1 | 1 | 1 |
