OPA2836-Q1器件是一款双通道超低功耗,轨到轨输出,负电源轨输入,电压反馈运算放大器,经过设计可由2.5V至5.5V范围内的单电源或者±1.25V至±2.75V范围内的双电源供电运行。该放大器每通道仅消耗1mA的电流,单位增益带宽为205MHz,功耗性能比处于业内领先水平。
OPA2836-Q1器件兼兼低功耗特性和出色的高频性能,并且可实现其他同类器件所无法达到的性能/功耗比,因此非常适合注重功耗方面的电池供电类便携式应用。
OPA2836-Q1在-40°C至+ 125°C的扩展级工业温度范围内额定运行。
所有商标均为其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA2836-Q1 | OPA2836 | OPA835 | OPA836 |
| Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB |
| 2 | 2 | 1 | 1 |
| 2.5 | 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 | 5.5 |
| 205 | 205 | 56 | 205 |
| 1 | 1 | 1 | 1 |
| 560 | 560 | 160 | 560 |
| 4.6 | 4.6 | 9.3 | 4.6 |
| 5 | 4.6 | 9.3 | 4.6 |
| 1 | 1 | 0.25 | 1 |
| 0.4 | 0.4 | 0.5 | 0.4 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| N/A | Small Size Shutdown | Small Size Shutdown | Small Size Shutdown |
| Automotive | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| VSSOP | QFN SOIC UQFN VSSOP | QFN SOT-23 | QFN SOT-23 |
| 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 10UQFN: 4 mm2: 2 x 2(UQFN) 10VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 10QFN: 4 mm2: 2 x 2(QFN) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 10QFN: 4 mm2: 2 x 2(QFN) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 116 | 116 | 113 | 116 |
| 1000000 | 1000000 | 400000 | 1000000 |
| 1.1 | 1.1 | 2.25 | 1.1 |
| 110 | 120 | 30 | 120 |
| 50 | 50 | 40 | 50 |
| 85 | 85 | 70 | 85 |
| 79 | 79 | 73 | 79 |
| 1 | 1 | 1 | 1 |
