数据: OPA355-Q1 200-MHz CMOS Operational Amplifier With Shutdown 数据表
OPA355-Q1器件是一款高速,电压反馈CMOS运算放大器,专为需要宽带宽的应用而设计。 OPA355-Q1器件具有单位增益稳定性,可以驱动大输出电流。此外,OPA355-Q1器件具有数字关断(使能)功能。此功能可在空闲期间提供省电功能,并将输出置于高阻抗状态以支持输出多路复用。差分增益为0.02%,差分相位为0.05°。每通道静态电流为8.3 mA。
OPA355-Q1器件针对单电源或双电源工作进行了优化,低至2.5 V(±1.25 V),最高5.5 V(±2.75 V) 。 OPA355-Q1器件的共模输入范围在低于地电位100 mV,从V +向高达1.5 V.输出摆幅在100 mV以内,支持宽动态范围。
OPA355-Q1器件采用单SOT-23-6封装,额定温度范围为-40°C至+ 125° °C温度范围。
所有tra demarks是其各自所有者的财产。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA355-Q1 |
| CMOS Voltage FB |
| 1 |
| 2.7 |
| 5.5 |
| 450 |
| 1 |
| 300 |
| 5.8 |
| 5.8 |
| 8.3 |
| 9 |
| In to V- Out |
| Shutdown |
| Automotive |
| -40 to 125 |
| SOT-23 |
| 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 80 |
| 50 |
| 7 |
| 450 |
| 100 |
| 81 |
| 93 |
| 1 |
