OPA2830是一款双通道,低功耗,单电源,宽带,电压反馈放大器,采用+ 3V或+ 5V单电源供电。还支持±5V或+ 10V电源供电。输入范围延伸到地电压以下,并且在正电源的1.8V范围内。使用互补的共发射极输出提供输出摆幅,在地面25mV以内,+ V S ,同时驱动150 。高输出驱动电流(75mA)和低差分增益和相位误差也使其成为单电源消费类视频产品的理想选择。
高增益带宽积(100MHz)和压摆率确保低失真工作(500V /μs),使OPA2830成为3V和5V CMOS模数转换器(ADC)的理想输入缓冲级。与早期的低功耗单电源放大器不同,失真性能随着信号摆幅的降低而提高。低9.2nV /
Hz 输入电压噪声支持宽动态范围操作。
OPA2830采用行业标准SO-8封装。 OPA2830还采用小型MSOP-8封装。对于固定增益和线路驱动器应用,请考虑OPA2832。
Hz 所有其他商标均为其各自所有者的财产。 < /p>
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| OPA2830 | OPA4830 | OPA830 |
| Bipolar Voltage FB | Bipolar Voltage FB | Bipolar Voltage FB |
| 2 | 4 | 1 |
| 2.8 | 2.8 | 2.8 |
| 11 | 11 | 11 |
| 290 | 280 | 310 |
| 1 | 1 | 1 |
| 560 | 560 | 600 |
| 9.2 | 9.2 | 9.2 |
| 9.5 | 9.5 | 9.5 |
| 4.25 | 4.25 | 4.25 |
| 7.5 | 8 | 7 |
| In to V- Out | In to V- Out | In to V- Out |
| N/A | N/A | N/A |
| Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 85 |
| SOIC VSSOP | TSSOP | SOIC SOT-23 |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 80 | 80 | 80 |
| 10000000 | 10000000 | 10000000 |
| 27 | 30 | 25 |
| 290 | 280 | 310 |
| 75 | 75 | 80 |
| 66 | 60 | 67 |
| 77 | 59 | 60 |
| 5 | 5 | 5 |
