THS6012包含两个高速驱动器,能够为25Ω负载提供400 mA输出电流(min)。这些驱动器可以差分配置,以通过低阻抗线路驱动50 V PP 输出信号。这些驱动器是电流反馈放大器,专为在xDSL应用中支持低总谐波失真(THD)所需的高压摆率而设计。 THS6012非常适用于中心局的非对称数字用户线(ADSL)应用,它支持该应用的高峰值电压和电流要求。
为每个驱动器提供单独的电源连接最小化串扰。 THS6012采用小型表面贴装,耐热增强型20引脚PowerPAD封装。
PowerPAD是德州仪器的商标。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS6012 |
| Current FB |
| 2 |
| 9 |
| 33 |
| 140 |
| 1 |
| 1300 |
| 1.7 |
| 1.8 |
| 11.5 |
| 5 |
| No |
| N/A |
| Catalog |
| -40 to 85 0 to 70 |
| SO PowerPAD |
| 20SO PowerPAD: 133 mm2: 10.405000000000001 x 12.825(SO PowerPAD) |
| 70 |
| 10000000 |
| 20 |
| 140 |
| 500 |
| 80 |
| 85 |
| 1 |
