THS4011和THS4012是高速,单/双电压反馈放大器,适用于各种应用。这些器件具有良好的交流性能,带宽为290 MHz,压摆率为310 V /μs,建立时间为37 ns(0.1%)。这些放大器具有110 mA的高输出驱动能力,每通道仅消耗7.8 mA电源电流。对于要求低失真的应用,THS4011 /4012在f = 1 MHz时的总谐波失真(THD)为-80 dBc。对于视频应用,THS4011 /4012提供0.1 dB增益平坦度至70 MHz,0.006%差分增益误差和0.01°差分相位误差。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4011 | THS4012 |
| Bipolar Voltage FB | Bipolar Voltage FB |
| 1 | 2 |
| 10 | 10 |
| 30 | 30 |
| 290 | 290 |
| 1 | 1 |
| 310 | 310 |
| 7.5 | 7.5 |
| 7.5 | 7.5 |
| 7.8 | 7.8 |
| 6 | 6 |
| No | No |
| N/A | N/A |
| Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| MSOP-PowerPAD SOIC | MSOP-PowerPAD SOIC |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 110 | 110 |
| 6000000 | 6000000 |
| 15 | 15 |
| 290 | 290 |
| 110 | 110 |
| 80 | 80 |
| 80 | 80 |
| 1 | 1 |
