SN74CBT3125四路FET总线开关具有独立的线路开关。当相关的输出使能(OE)输入为高电平时,每个开关都被禁用。
为确保上电或断电期间的高阻态,OE \应连接到V CC 通过上拉电阻;电阻的最小值由驱动器的电流吸收能力决定。
在两个端口之间切换连接
| Configuration |
| Number of Channels (#) |
| Power Supply Type |
| Vss (Min) (V) |
| Vss (Max) (V) |
| Vdd (Min) (V) |
| Vdd (Max) (V) |
| Ron (Typ) (Ohms) |
| Bandwidth (MHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Size: mm2:W x L (PKG) |
| Package Group |
| Supply Range (Max) |
| Ron (Max) (Ohms) |
| Input/Output Continuous Current (Max) (mA) |
| Supply Current (Typ) (uA) |
| Supply Current (Max) (uA) |
| Features |
| OFF-state leakage current (Max) (µA) |
| ON-state leakage current (Max) (µA) |
| Input/Output ON-state Capacitance (Typ) (pF) |
| Input/Output OFF-state Capacitance (Typ) (pF) |
| ESD Charged Device Model (kV) |
| ESD HBM (kV) |
| VIL (Max) (V) |
| VIH (Min) (V) |
| SN74CBT3125 | SN74CB3Q3125 | SN74CBTLV3125 |
| 1:1 SPST | 1:1 SPST | 1:1 SPST |
| 4 | 4 | 4 |
| Single | Single | Single |
| N/A | N/A | N/A |
| N/A | N/A | N/A |
| 4 | 2.3 | 2.3 |
| 5.5 | 3.6 | 3.6 |
| 5 | 4 | 5 |
| 200 | 500 | 200 |
| Catalog | Catalog | Catalog |
| -40 to 85 | -40 to 85 | -40 to 85 |
| 14SOIC: 52 mm2: 6 x 8.65(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 14SSOP: 48 mm2: 7.8 x 6.2(SSOP) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) 14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 14VQFN: 12 mm2: 3.5 x 3.5(VQFN) | 16SSOP: 29 mm2: 6 x 4.9(SSOP) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) 14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 14VQFN: 12 mm2: 3.5 x 3.5(VQFN) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 16SSOP: 29 mm2: 6 x 4.9(SSOP) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) 14TVSOP: 23 mm2: 6.4 x 3.6(TVSOP) 14VQFN: 12 mm2: 3.5 x 3.5(VQFN) |
| SOIC SSOP SSOP TSSOP TVSOP VQFN | SSOP TSSOP TVSOP VQFN | SOIC SSOP TSSOP TVSOP VQFN |
| 5.5 | 3.6 | 3.6 |
| 22 | 9 | 40 |
| 128 | 64 | 128 |
| 2000 | ||
| 3 | 4000 | 10 |
| Powered off protection | Powered off protection | |
| 1 | 1 | 1 |
| 1 | 1 | 1 |
| 8 | ||
| 4 | 4 | 7 |
| 1 | ||
| 2 | ||
| 0.8 | 0.8 | 0.8 |
| 2 | 1.7 | 2 |
