数据: LM26LV and LM26LV-Q1 1.6-V, WSON-6 Factory Preset Temperature Switch and Temperature Sensor 数据表
The LM26LV and LM26LV-Q1 are low-voltage, precision, dual-output, low-power temperature switches and temperature sensors. The temperature trip point (TTRIP) can be preset at the factory to any temperature in the range of 0°C to 150°C in 1°C increments. Built-in temperature hysteresis (THYST) keeps the output stable in an environment of temperature instability.
In normal operation the LM26LV or LM26LV-Q1 temperature switch outputs assert when the die temperature exceeds TTRIP. The temperature switch outputs will reset when the temperature falls below a temperature equal to (TTRIP – THYST). The OVERTEMP digital output, is active-high with a push-pull structure, while the OVERTEMP digital output, is active-low with an open-drain structure.
The analog output, VTEMP, delivers an analog output voltage with Negative Temperature Coefficient (NTC).
Driving the TRIP_TEST input high causes the digital outputs to be asserted for in-situ verification and causes the threshold voltage to appear at the VTEMP output pin, which could be used to verify the temperature trip point.
The LM26LVs and LM26LV-Q1s low minimum supply voltage makes them ideal for 1.8-V system designs. The wide operating range, low supply current, and excellent accuracy provide a temperature switch solution for a wide range of commercial and industrial applications.
| Operating Temperature Range (C) |
| Accuracy Over Temp Range (Max) (C) |
| Sensor Gain (mV/Deg C) |
| SetPoint Value (deg C) |
| SetPoint Type |
| Output Type |
| Supply Voltage (Min) (V) |
| Supply Voltage (Max) (V) |
| Supply Current (Typ) (uA) |
| Comparator Channels (#) |
| Features |
| Rating |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Interface |
| LM26LV-Q1 | LM26LV | LM57-Q1 | TMP300-Q1 | TMP302-Q1 | TMP708 | TMP708-Q1 | TMP709 | TMP709-Q1 |
| -40 to 150 | 0 to 150 | -50 to 125 -50 to 150 -50 to 160 | -40 to 125 | -40 to 125 | -40 to 125 | 0 to 125 | -40 to 125 | 0 to 125 |
| 2.3 | 2.3 | 1.3 | 2 | 2 | 3 | 3 | 3 | 3 |
| -5.1 to -12.8 | -5.1 to -12.8 | -5.2 to 12.9 | 10 | |||||
| Range (0 to 150) 130, 135 | Range (0 to 150) 50, 60, 65, 70 75, 80, 85, 90 95, 100, 105, 110 115, 120, 125, 130 135, 140, 145, 150 | -40 to 160 | -40 to 125 | 50, 55, 60, 65 70, 75, 80, 85 90, 95, 100, 105 110, 115, 120, 125 | 0 to 125 | 0 to 125 | 0 to 125 | 0 to 125 |
| Factory Programmed | Factory Programmed | Resistor Programmable | Resistor Programmable | Pin-Selectable | Resistor Programmable | Resistor Programmable | Resistor Programmable | Resistor Programmable |
| Open Drain Push Pull | Open Drain Push Pull | Open Drain Push Pull | Open Drain | Open Drain | Open Drain | Open Drain | Open Drain | Open Drain |
| 1.6 | 1.6 | 2.4 | 1.8 | 1.4 | 2.7 | 2.7 | 2.7 | 2.7 |
| 5.5 | 5.5 | 5.5 | 18 | 3.6 | 5.5 | 5.5 | 5.5 | 5.5 |
| 8 | 8 | 24 | 110 | 8 | 40 | 40 | 40 | 40 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch Trip Test | Built-in Hysteresis Hysteresis (5°C) Temperature Sensor and Switch Trip Test | Built-in Hysteresis Hysteresis (5°C or 10°C) Temperature Sensor and Switch Trip Test | Hysteresis (5°C or 10°C) Pin-Selectable Hysteresis Temperature Sensor and Switch | Hysteresis (5°C or 10°C) Pin-Selectable Hysteresis | Hysteresis (10°C or 30°C) Pin-Selectable Hysteresis | Hysteresis (10°C or 30°C) Pin-Selectable Hysteresis | Hysteresis (2°C or 10°C) Pin-Selectable Hysteresis | Hysteresis (2°C or 10°C) Pin-Selectable Hysteresis |
| Automotive | Catalog | Automotive | Automotive | Automotive | Catalog | Automotive | Catalog | Automotive |
| WSON | WSON | TSSOP | SC70 | SOT-5X3 | SOT-23 | SOT-23 | SOT-23 | SOT-23 |
| See datasheet (WSON) | See datasheet (WSON) | 8TSSOP: 19 mm2: 6.4 x 3(TSSOP) | 6SC70: 4 mm2: 2.1 x 2(SC70) | 6SOT-5X3: 3 mm2: 1.6 x 1.6(SOT-5X3) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| Analog Output Switch | Analog Output Switch | Analog Output Switch | Analog Output Switch | Switch | Switch | Switch | Switch | Switch |
