TMP709 采用 SOT-23 封装的电阻可编程温度开关。10C 或 2C 滞后选项。
数据:
TMP709是一款完全集成的,可编程电阻器温度开关,在其全工作范围内,只需一个外部电阻器即可设定温度阀值。温度阀值。温度阀值精度的典型值为±0.5°C而最大值为±3°C(+ 60°C至+ 100°C时)。静态流耗的典型值为40μA。可通过引脚选择来确定2°C或者10°C的温度滞后。
TMP709采用5引脚SOT23封装。
特性
  • 阀值精度:
    • 典型值±0.5°C
    • 最大值±3°C (+ 60°C至+ 100°C时)
  • 由1%外部电阻器设定的温度阀值
  • 低静态电流:典型值为40μA
  • 开漏,低电平有效输出级
  • 可通过引脚选择的2°C或者10°C温度滞后
  • V CC = 0.8V上指定的复位操作
  • 电源范围:2.7V至5.5V
  • 封装方式:5引脚SOT23
  • < /ul>
参数 与其它产品相比 温度开关
Operating Temperature Range (C)
Accuracy Over Temp Range (Max) (C)
Sensor Gain (mV/Deg C)
SetPoint Value (deg C)
SetPoint Type
Output Type
Supply Voltage (Min) (V)
Supply Voltage (Max) (V)
Supply Current (Typ) (uA)
Comparator Channels (#)
Features
Rating
Package Group
Package Size: mm2:W x L (PKG)
Interface
TMP709 LM26LV LM26LV-Q1 LM56 LM57 LM57-Q1 TMP300 TMP300-Q1 TMP708 TMP708-Q1 TMP709-Q1
-40 to 125     0 to 150     -40 to 150     -40 to 125     -50 to 150     -50 to 125
-50 to 150
-50 to 160
-40 to 125     -40 to 125     -40 to 125     0 to 125     0 to 125
3     2.3     2.3     3     1.5     1.3     2     2     3     3     3
  -5.1 to -12.8     -5.1 to -12.8     6.2     -5.2 to -12.9     -5.2 to 12.9     10     10
0 to 125     Range (0 to 150)
50, 60, 65, 70
75, 80, 85, 90
95, 100, 105, 110
115, 120, 125, 130
135, 140, 145, 150
Range (0 to 150)
130, 135
-40 to 125     -40 to 150     -40 to 160     -40 to 125     -40 to 125     0 to 125     0 to 125     0 to 125
Resistor Programmable     Factory Programmed     Factory Programmed     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable     Resistor Programmable
Open Drain     Open Drain
Push Pull
Open Drain
Push Pull
Push Pull
Open Drain
Push Pull
Open Drain     Open Drain     Open Drain     Open Drain     Open Drain
2.7     1.6     1.6     2.7     2.4     2.4     1.8     1.8     2.7     2.7     2.7
5.5     5.5     5.5     10     5.5     5.5     18     18     5.5     5.5     5.5
40     8     8     230     24     24     110     110     40     40     40
1     1     1     2     1     1     1     1     1     1     1
Hysteresis (2°C or 10°C)
Pin-Selectable Hysteresis
Built-in Hysteresis
Hysteresis (5°C)
Temperature Sensor and Switch
Trip Test
Built-in Hysteresis
Hysteresis (5°C)
Trip Test
Built-in Hysteresis
Hysteresis (5°C)
Built-in Hysteresis
Hysteresis (5°C or 10°C)
Trip Test
Built-in Hysteresis
Trip Test
Hysteresis (10°C or 30°C)
Catalog     Catalog     Automotive     Catalog     Catalog     Automotive     Catalog     Automotive     Catalog     Automotive     Automotive
SOT-23     WSON     WSON     SOIC
VSSOP
TSSOP
WSON
TSSOP     SC70
SOT-23
SC70     SOT-23     SOT-23     SOT-23
5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     See datasheet (WSON)     See datasheet (WSON)     8SOIC: 29 mm2: 6 x 4.9(SOIC)
8VSSOP: 15 mm2: 4.9 x 3(VSSOP)
8TSSOP: 19 mm2: 6.4 x 3(TSSOP)
8TSSOP: 19 mm2: 6.4 x 3(TSSOP)     6SC70: 4 mm2: 2.1 x 2(SC70)
6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
6SC70: 4 mm2: 2.1 x 2(SC70)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)     5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Switch     Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Analog Output
Switch
Switch     Switch     Switch
技术文档
数据手册(1)
元器件购买 TMP709 相关库存
