CDCE62002 具有集成双路 VCO 的 4 路输出时钟发生器/抖动消除器
数据:
产品信息
描述The CDCE62002 device is a high-performance clock generator featuring low output jitter, a high degree of configurability through a SPI interface, and programmable start-up modes determined by on-chip EEPROM. Specifically tailored for clocking data converters and high-speed digital signals, the CDCE62002 achieves jitter performance under 0.5 ps RMS(1). It incorporates a synthesizer block with partially integrated loop filter, a clock distribution block including programmable output formats, and an input block featuring an innovative smart multiplexer. The clock distribution block includes two individually programmable outputs that can be configured to provide different combinations of output formats (LVPECL, LVDS, LVCMOS). Each output can also be programmed to a unique output frequency (ranging from 10.94 MHz to 1.175 GHz(2)). If Both outputs are configured in single-ended mode (such as LVCMOS), the CDCE62002 supports up to four outputs. The input block includes one universal differential inputs which support frequencies up to 500 MHz and an auxiliary input that can be configured to connect to an external AT-Cut crystal through an onboard oscillator block. The smart input multiplexer has two modes of operation, manual and automatic. In manual mode, the user selects the synthesizer reference through the SPI interface. In automatic mode, the input multiplexer will automatically select between the highest priority input clock available.(1) 10-kHz to 20-MHz integration bandwidth. (2) Frequency range depends on operational mode and output format selected.特性Frequency Synthesizer With PLL/VCO and Partially Integrated Loop FilterFully Configurable Outputs Including Frequency and Output FormatSmart Input Multiplexer Automatically Switches Between One of Two Reference InputsMultiple Operational Modes Include Clock Generation Through Crystal, SERDES Start-Up Mode, Jitter Cleaning, and Oscillator Based Holdover ModeIntegrated EEPROM Determines Device Configuration at Power UpExcellent Jitter PerformanceIntegrated Frequency Synthesizer Including PLL, Multiple VCOs, and Loop Filter: Full Programmability Facilitates Phase Noise Performance Optimization Enabling Jitter Cleaner ModeProgrammable Charge Pump Gain and Loop Filter SettingsUnique Dual-VCO Architecture Supports a Wide Tuning Range 1.750 GHz to 2.356 GHz.Universal Output Blocks Support Up to 2 Differential, 4 Single-Ended, or Combinations of Differential or Single-Ended: 0.5 ps RMS (10 kHz to 20 MHz) Output Jitter PerformanceLow Output Phase Noise: –130 dBc/Hz at 1 MHz Offset, Fc = 491.52 MHz Output Frequency Ranges From 10.94 MHz to 1.175 GHz in Synthesizer ModeLVPECL, LVDS, and LVCMOSIndependent Output Dividers Support Divide Ratios for 1, 2, 3, 4, 5, 8, 10, 12, 16, 20, 24, and 32Flexible Inputs With Innovative Smart Multiplexer: Two Universal Differential Inputs Accept Frequencies from 1 MHz up to 500 MHz (LVPECL), 500 MHz (LVDS), or 250 MHz (LVCMOS)One Auxiliary Input Accepts Crystals in the Range of 2 MHz to 42 MHzClock Generator Mode Using Crystal InputSmart Input Multiplexer Can be Configured to Automatically Switch Between Highest Priority Clock Source Available Allowing for Fail-Safe Operation Typical Power Consumption 750 mW at 3.3 VIntegrated EEPROM Stores Default Settings; Therefore, the Device Can Power Up in a Known, Predefined StateOffered in QFN-32 PackageESD Protection Exceeds 2000 V HBMIndustrial Temperature Range: –40°C to +85°CAPPLICATIONSData Converter and Data Aggregation ClockingWireless InfrastructureSwitches and RoutersMedical ElectronicsMilitary and AerospaceIndustrialClock Generation and Jitter Cleaning All other trademarks are the property of their respective owners
电路图、引脚图和封装图
技术文档
数据手册(1) 相关资料(1)
元器件购买 CDCE62002 相关库存
相关阅读
