数据: DS90LV012A / DS90LT012A 3V LVDS Single CMOS Differential Line Receiver 数据表
DS90LV012A和DS90LT012A是单CMOS差分线路接收器,专为需要超低功耗,低噪声和高数据速率的应用而设计。这些器件采用低压差分摆幅(LVDS)技术,支持超过400 Mbps(200 MHz)的数据速率。
DS90LV012A和DS90LT012A接受低电压(350 mV典型值)差分输入信号并进行转换它们达到3V CMOS输出电平。接收器还支持开路,短路和端接(100Ω)输入故障安全。所有故障安全条件下,接收器输出均为高电平。 DS90LV012A具有引脚排列,便于PCB布局。 DS90LT012A包括一个用于点对点应用的输入线路终端电阻。
DS90LV012A和DS90LT012A以及配套LVDS线路驱动器为高速接口应用提供了高功率PECL /ECL器件的新替代方案。
全部商标是他们的财产各自所有者。
| Device Type |
| Protocols |
| No. of Tx |
| No. of Rx |
| Input Signal |
| Output Signal |
| Signaling Rate (Mbps) |
| ESD HBM (kV) |
| Function |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| DS90LV012A | DS90LV011A | DS90LV017A | DS90LV027A | DS90LV028A | DS90LV028AQ-Q1 | DS90LV031A | DS90LV032A | DS90LV047A | DS90LV048A | SN65LVDS1 | SN65LVDS179 | SN65LVDS180 | SN65LVDS2 | SN65LVDS349 | SN65LVDS391 | SN65LVDS4 | SN65LVDS9637 | SN65LVDS9638 | SN65LVDT2 |
| Receiver | Driver | Driver | Driver | Receiver | Receiver | Driver | Receiver | Driver | Receiver | Driver | Transceiver | Transceiver | Receiver | Receiver | Driver | Receiver | Receiver | Driver | Receiver |
| M-LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS | LVDS |
| 0 | 1 | 1 | 2 | 0 | 0 | 4 | 0 | 4 | 0 | 1 | 1 | 1 | 0 | 0 | 4 | 0 | 0 | 2 | 0 |
| 1 | 0 | 0 | 0 | 2 | 2 | 0 | 4 | 0 | 4 | 0 | 1 | 1 | 1 | 4 | 0 | 1 | 2 | 0 | 1 |
| LVDS BLVDS LVPECL | LVTTL LVCMOS | TTL CMOS | TTL CMOS | LVDS | LVDS | LVTTL LVCMOS | LVDS | TTL LVTTL CMOS | LVDS | LVTTL | LVDS LVTTL | LVDS LVTTL | LVDS | CMOS ECL LVCMOS LVDS LVECL LVPECL PECL | LVTTL | LVDS | LVDS | LVTTL | LVDS |
| CMOS | LVDS | LVDS | LVDS | TTL LVTTL | TTL LVTTL | LVDS | LVCMOS | LVDS | TTL LVTTL | LVDS | LVDS LVTTL | LVDS LVTTL | LVTTL | LVTTL | LVDS | LVTTL LVCMOS | LVTTL | LVDS | LVTTL |
| 400 | 400 | 600 | 600 | 400 | 400 | 400 | 400 | 400 | 400 | 630 | 400 150 | 400 150 | 400 | 560 | 630 | 500 | 150 | 400 | 400 |
| 2 | 9 | 8 | 8 | 7 | 8 | 6 | 4.5 | 10 | 10 | 9 | 12 | 12 | 9 | 15 | 15 | 2 | 8 | 8 | 9 |
| -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| SOT-23 | SOT-23 | SOIC | SOIC | SOIC WSON | SOIC | SOIC TSSOP | SOIC TSSOP | SOIC TSSOP | SOIC TSSOP | SOIC SOT-23 | SOIC VSSOP | SOIC TSSOP | SOIC SOT-23 | TSSOP | SOIC TSSOP | UQFN | MSOP-PowerPAD SOIC VSSOP | MSOP-PowerPAD SOIC VSSOP | SOIC SOT-23 |
| 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) See datasheet (WSON) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16SOIC: 59 mm2: 6 x 9.9(SOIC) 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) |
| 5SOT-23 | 5SOT-23 | 8SOIC | 8SOIC | 8SOIC 8WSON | 8SOIC | 16SOIC 16TSSOP | 16SOIC 16TSSOP | 16SOIC 16TSSOP | 16SOIC 16TSSOP | 5SOT-23 8SOIC | 8SOIC 8VSSOP | 14SOIC 14TSSOP | 5SOT-23 8SOIC | 16TSSOP | 16SOIC 16TSSOP | 10UQFN | 8MSOP-PowerPAD 8SOIC 8VSSOP | 8MSOP-PowerPAD 8SOIC 8VSSOP | 5SOT-23 8SOIC |
