数据: 具有 16V/20V 过压保护功能的 TS5USBC41 双路 2:1 USB 2.0 多路复用器/多路信号分离器或单端交叉开关 数据表
TS5USBC41是一款双向低功耗双端口高速USB 2.0模拟开关,具有针对USB Type-C™系统的集成保护功能。该器件配置为双路2:1或1:2开关,并经过了优化,能够应对USB Type-C™系统中的USB 2.0 D +/-线路。
TS5USBC41在I /O引脚上的保护功能可承受高达16V(TS5USBC410)或20V(TS5USBC412)的电压,并配备自动关闭电路来保护开关后面的系统组件。
TS5USBC41采用小型12引脚DSBGA封装,使其成为移动应用和空间受限型应用。
所有商标均为其各自所有者的财产。
| Device Type |
| Number of Channels (#) |
| Configuration |
| VCC (Min) (V) |
| VCC (Max) (V) |
| Ron (Typ) (Ohms) |
| Input/Ouput Voltage (Min) (V) |
| Input/Ouput Voltage (Max) (V) |
| ICC (Max) (uA) |
| Bandwidth (MHz) |
| ESD HBM (Typ) (kV) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Pin/Package |
| TS5USBC41 | TS3USB3000 | TS3USB3031 | TS3USB3200 | TS5USBC400 | TS5USBC402 |
| USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | |
| 2 | 2 | 2 | 2 | 2 | 2 |
| Dual 2:1 | 2:1 SPDT | 3:1 | 2:1 SPDT | Dual 2:1 | Dual 2:1 |
| 2.3 | 2.7 | 2.5 | 2.7 | 2.3 | 2.3 |
| 5.5 | 4.3 | 4.3 | 4.3 | 5.5 | 5.5 |
| 5.6 | 4.6 | 4.5 | 4.6 | 5.6 | 5.6 |
| 0 | 0 | 0 | 0 | 0 | 0 |
| 18 | 3.6 | 3.6 | 3.6 | 18 | 20 |
| 22 | 50 | 40 | 70 | 100 | 100 |
| 1200 | 6100 | 6500 | 5500 | 1200 | 1200 |
| 2 | 3.5 | 2 | 3.5 | 2 | 2 |
| 20V Over Voltage Protection Very low power consumption | USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Logic Controlled (Output Enabled) | USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Logic Controlled (Output Enabled) | USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Flexible Power Control Logic Controlled (Output Enabled) | 16V Over Voltage Protection | 20V Over Voltage Protection |
| Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| DSBGA | UQFN | WQFN | UQFN | DSBGA | DSBGA |
| See datasheet (DSBGA) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) | 12WQFN: 3 mm2: 1.8 x 1.8(WQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) |
| 12DSBGA | 10UQFN | 12WQFN | 16UQFN | 12DSBGA | 12DSBGA |
